Drag Racing Tech
View Poll Results: Which is a better buy?
Harlan Shift Light $50
56.94%
Raptor Shift Light $85
43.06%
Voters: 72. You may not vote on this poll
Why Raptor over Harlan?
Old 12-20-2006, 09:55 PM
  #41
Mean Green z28's Avatar
Harlen Shift light here, works GOOD! Took it apart and extended the wiring to the LED's and mounted the control unit under the dash and the lights in a hole I made on the dash next to the A/C controls. Looks PIMP!
Old 01-06-2007, 10:42 PM
  #42
Install Director
wizkid's Avatar
Harlan, because he is old school.
Old 01-07-2007, 04:41 PM
  #43
mthegodfather's Avatar
Where can you get the Raptor at?
Old 01-10-2007, 04:06 PM
  #44
STL2SLO's Avatar
I finally put mine in last Sat and it works great!
Old 01-10-2007, 10:57 PM
  #45
2_wacko's Avatar
Just got my Raptor shift light in the mail, looks great.
Old 01-12-2007, 10:16 AM
  #46
ZFan88's Avatar
Where do the LT1 guys mount them??
Old 01-12-2007, 03:06 PM
  #47
2_wacko's Avatar
Mounted mine on the dash so it can stare right at me, nothing fancy.
Old 03-11-2007, 07:26 AM
  #48
CT ITALIAN 1's Avatar
when you install the raptor in defroster vent, do you need to cut that hose or just stick the shift light in that? and put the gromet on the end? anyone have a writeup on the rapter defroster install?
Old 06-06-2007, 01:40 AM
  #49
6techniques's Avatar
well, I went the Harlan route, waited a couple weeks to get it and then sat it on a shelf for about a month...then I finally got around to installing it and BAM! it doesnt work...The lights come on just fine during "power up" but for some reason it doesnt receive the tach signal so I basically waisted $55...Oh well, it looks like I'll be installing a tach w/ a shiftlight instead.
Old 06-06-2007, 03:43 AM
  #50
y2khawk's Avatar
Have you checked your wiring before you assume the light is broken? Do you have it set properly, IE 4 cylinder mode?
I always tell people to set it very low to check it, that way you can catch an improper cylinder setting.
Old 06-06-2007, 04:47 AM
  #51
Race your car!
JL ws-6's Avatar
I've been running the harlan light in my car for about 5 years now, no problems whatsoever.
Old 06-06-2007, 06:51 AM
  #52
LS1TECH Sponsor
badpewter-z's Avatar
thats what im thinking, bad or no signal from where you got your tach signal or on the wrong setting. id make sure the signal is good first
Old 06-06-2007, 10:36 AM
  #53
Yes I made 300-500 rpm adjustments from about 1k-rpm up to 5500rpm and nothing...I tapped into the correct location for the signal but for some reason it just wont come on.
Edit: Wow, I played with it again this morning (that doesnt even sound right, lol) and it came on @ the 2500 rpm setting, but when I brought it up to 3k, it stopped working again...idk what the deal is with that thing.
Also Harlan, let me apologize if I came off as bashing you as that wasnt my intent, I was just frustrated with dealing with the light and voiced my problem so maybe someone could shed some light on the situation.
Old 06-06-2007, 03:27 PM
  #54
94StevesZ's Avatar
Harlan is a standup guy. If the unit is bad, he will definately make it good! Just make sure that the problem is with the light and not something else.
Attached Thumbnails Why Raptor over Harlan?-slight-1.jpg   Why Raptor over Harlan?-slight-2.jpg   Why Raptor over Harlan?-slight-3.jpg   Why Raptor over Harlan?-slight-4.jpg
Old 06-07-2007, 01:09 PM
  #55
01slowbird's Avatar
ordered mine today, cant wait to install
Old 06-09-2007, 09:20 AM
  #56
Tony @ MPH's Avatar
I'm running the Raptor red led/black housing in my personal car (2003 twin turbo Z06). Needless to say with almost 800hp at the wheels, 1st-3rd gear come up fast and the oem tach just cannot keep up.
I can't say which is better (Harlan over Raptor) since I've only ever owned a Raptor, but I can tell you that the Raptor is worth every dollar to me personally. I bought it retail through Raptor about a year ago (not through our store).
For me, the things I liked about the shift light hookup were:
(a) ease of install -- just 3 wires to connect, all of which were behind the knee bolster in my Z06 leading to the instrument cluster. only took around an hour for me to install.
(b) settings are accessible once installed -- the Raptor sort of 'snaps' into place into a C-clip, so it's very easy for me to pull the unit out to adjust RPM on it... furthermore, RPM is adjusted using simple rotary dials so it's very intuitive how to adjust it at the track if need be.
(c) it's tiny enough to go into my a-pillar without being obvious. when I built this car I wanted it to be stealth so I didn't want massive gauges and lights sticking out of my pillar. I mounted the shift light up high as you can see in the pic below and you can hardly tell it's there from outside the car.
Looks good, more than visible from inside, but from any angle outside you can't see it. Specifically, I tried a few different angles I thought a police officer might be standing from
The last pic is a close up of the rotary dials and dip switches. The dip switches are used for cylinder selection only and then left alone after initial setting. As you can see the rotary dials are user friendly -- my shift light is set to 6000rpm in this picture.
<shameless plug>
We are currently running a free shipping special on the Raptor lights if anyone is interested. These will be in stock and ready to ship at the end of this week. Ordinarily there would not be a shipping delay like this, but Raptor has announced a $20 price increase coming in July so a lot of people are ordering or stocking up on these lights. Now is definitely the time to pick one up if you are interested.
http://www.mphparts.com/mm5/merchant...egory_Code=UNV
</shameless plug>
Old 06-09-2007, 10:59 AM
  #57
LS1TECH Sponsor
Magnus's Avatar
Harlan is an old school LS1 Tech'er. I'd support Harlan. He's helped out quite a bit here.
Old 06-09-2007, 11:33 AM
  #58
Tony @ MPH's Avatar
+1 to that -- you can't put a price on someone like Harlan who has contributed so much knowledge (and products) to the LS1 community.
Old 06-15-2007, 02:57 PM
  #59
JD17825's Avatar
went to autozone the part number is 5339 it was two different sizes in the pack. thanks for the idea
Originally Posted by BriancWS6
I have the Raptor and I love it! After having it I couldn't go without it. It only takes seconds to change the settings on it. Someone said it was too small to fit in the defroster vent in the a-pillar....nope, I just got a valve cover gromment from Auto-Zone, brand name was Spectre, it fits perfect.
Quick Reply: Why Raptor over Harlan?
