Drag Racing Tech
Manual brake kit Q?
Old Nov 26, 2006 | 10:30 AM
Houston999's Avatar
speed inc. or ls1speed.com]
Old Nov 26, 2006 | 10:54 AM
Tim King's Avatar
Thanx, anyone know any coupon codes for them?
Old Nov 27, 2006 | 10:15 PM
TNTaddict's Avatar
Old Nov 27, 2006 | 10:22 PM
TNTaddict's Avatar
Old Nov 27, 2006 | 10:28 PM
TNTaddict's Avatar
Old Nov 27, 2006 | 10:58 PM
Houston999's Avatar
do you have bigger pictures ?
Old Nov 28, 2006 | 07:20 PM
TNTaddict's Avatar
went to Test the car....when i hit the brake pedal....it won't come back to it's normal postion (still holding the brakes and the car can't move) unless i pull it back ..i double checked every thing...and adjust the pedal twice....nothing works
what could be the problem??? (bleeding>>>twice also)
plz help...
Old Nov 28, 2006 | 07:32 PM
Dave88z's Avatar
What do you mean the car doesnt move? Even when you gas it? Is the return spring connected?
Old Nov 28, 2006 | 07:49 PM
Houston999's Avatar
i think that he means when he is staging , the pedal does not go back and te brake doe snot release the rotors.
Old Nov 28, 2006 | 07:51 PM
TNTaddict's Avatar
i ment the brakes still stoping the car from moving.....tried to launch it in the street...but it didn't move after releasing the brake pedal....
where exactlly is that spring??? i did every thing myself and didn't see any springs .....and if there is ...plz tell me where exactlly i can find it....
thx alot
Old Nov 29, 2006 | 04:31 PM
John_D.'s Avatar
Check all the bushings at the pedal to bracket, and at the pedal to pushrod, make sure nothing is binding.
How hard is it to pull the pedal back up by hand?
Old Nov 29, 2006 | 08:55 PM
  #32
Dave88z's Avatar
thx alot
Your car may not have and return springs on the pedal, I just thought I would mention it. Did you bench bleed the master cylinder? If so the piston inside the master should be hard to push in by hand, and spring back with force.
