Drag Racing Tech
Manual brake kit Q?
Old Nov 6, 2006 | 01:23 PM
TNTaddict's Avatar
Default Manual brake kit Q?
i'm looking for a break booster delete kit to my 01 Z/28.......and i found Billingsly Manual Brake Kit and they are offering an optional line lock for 80$....but i allready have the SLP one(line lock) it costed me 130$....the Q is ..can i keep my slp line lock??or i have to buy the new one??
and if there is a better kit ...plz mention it.....
thx in advance
Old Nov 6, 2006 | 01:33 PM
raceme9s's Avatar
I have the Billingsly Manual Brake Kit and love it , your line lock should work fine.
Old Nov 6, 2006 | 01:51 PM
John_D.'s Avatar
Same here. That's the only one I found too. Works fine. You have to make up some lines and do some flaring anyway, so you should be able to tie it into your existing line lock no problem.
Old Nov 6, 2006 | 05:03 PM
TNTaddict's Avatar
thx alot guys...
Old Nov 6, 2006 | 05:56 PM
SlickVert's Avatar
Is the Billingsly Manual brake kit streetable?
How much weight will it save?
Old Nov 6, 2006 | 07:04 PM
1QuickT-A's Avatar
Thats what I would like to know also. How much better does the car stop with the manual brakes over the power brakes?
Old Nov 6, 2006 | 07:45 PM
Steve Burger's Avatar
LS1TECH Sponsor
I have the kit. It takes a bit of getting used to. I don't do much street driving but it stops fine at the track. I have the Billingsly line lock as well. I sold the SLP one for the cost of the new one. Made the install a lot easier.
Old Nov 6, 2006 | 08:01 PM
Dave88z's Avatar
What do you mean by that statement? Is it strictly a pedal effort thing?
Old Nov 6, 2006 | 08:07 PM
LS1TECH Sponsor
For the most part yes. It will take a lot more pedal effort and you will need to relearn stopping distance. Having said that, I can haul my car down from 127 on a short shutdown track without issue.
Old Nov 7, 2006 | 09:57 AM
1998TA__1991RS's Avatar
ive driven several 1st gens with manual brakes. how would it compare to those?
Old Nov 7, 2006 | 05:40 PM
Dave88z's Avatar
I guess it can't be that bad if older cars had full manual brakes....but then again they were probably drums not discs. I think I want this kit but I sure wish I could get a feel for how much more pressure is needed.
Old Nov 7, 2006 | 09:01 PM
John_D.'s Avatar
One mod you have to make, is to move the rod up by 1" on the brake arm. Besides correcting the alignment of the moving parts, it gives you more leverage on the piston which helps.
Old Nov 10, 2006 | 04:37 PM
SlickVert's Avatar
What is the weight savings?
Old Nov 10, 2006 | 06:00 PM
TNTaddict's Avatar
just ordered it....will post every thing in a week or so...
Old Nov 11, 2006 | 10:32 AM
LS1TECH Sponsor
Weight savings is significant. I want to say like 20 - 25 lbs. You can get rid of the booster and the ABS stuff. It cleans up the engine bay quite a bit, I dud tue the ABS delete block instead of redoing the lines. I may change this if I go Strange brakes over the winter.
Pedal effort is quite a bit more with stock brakes. This kit was designed for drag brakes.
Old Nov 11, 2006 | 02:55 PM
SlickVert's Avatar
Thanks
Old Nov 11, 2006 | 02:56 PM
SlickVert's Avatar
Thanks,
I already got rid of the ABS and used the ABS Deletions Block, next the booster.
Old Nov 26, 2006 | 07:06 AM
TNTaddict's Avatar
Update...
just removed the break booster and the master cylinder.....=11 lb (Empty)
the new Billingsly Manual Brake Kit weigh 4 lb (Empty)......
So, about 7 lb only .....
Hope i can launch it @ 4500-5000 this time(fb).....and see some 1.4 60"....
will post some pics tomorrow.....
Old Nov 26, 2006 | 07:10 AM
TNTaddict's Avatar
yeah...i had to do that..
Old Nov 26, 2006 | 09:57 AM
Tim King's Avatar
What is the website for this kit?
