Drag Racing Tech
short belt question
Old Nov 12, 2006 | 02:19 PM
DMH Fabrication's Avatar
Default short belt question
I'm only running the alternator off the crank, but i'm having a problem finding a short enough belt. I can find a 3 rib belt that will fit perfect or I can get a 4 rib one that is a little longer. The4 rib will work if i remake the alternator brackets. Do you all think the 3 rib will be enough since its only running the alternator?
Old Nov 12, 2006 | 08:05 PM
BKHAWK1's Avatar
it should be. why not run it around the idler pully and tensoner as well?
Old Nov 12, 2006 | 08:22 PM
Its not a factory engine set up that ever had a tensioner or anything. Its all one off to clear the turbo headers, intercooler pipes, etc.
Old Nov 13, 2006 | 04:10 PM
BKHAWK1's Avatar
I see!! three should be enough. I would put it on the back three ribs so if it does move any, you have some room in the front.
Old Nov 13, 2006 | 04:25 PM
alright. i'll stick it on like that. thanks!
