Drag Racing Tech
Harlan 2-step
Old Dec 10, 2006 | 08:29 AM
The1N_only's Avatar
Default Harlan 2-step
I just came across one. How should i go abouts wiring it? Its pretty much plug and play except the 3 wires. I didn't getting and wiring diagrams with it or anything like that. Any Help would be nice and also where did you mount yours at?
Old Dec 10, 2006 | 01:01 PM
y2khawk's Avatar
https://ls1tech.com/forums/attachmen...chmentid=39259
Old Dec 10, 2006 | 01:16 PM
The1N_only's Avatar
Thanks, I understand what to do with the white and gray wires. Where does the yellow hook up to? Do i need a relay?
Old Dec 10, 2006 | 04:17 PM
y2khawk's Avatar
only if you plan to turn off a WOT switch activated nitrous system, or you want an indicator showing the 2 step is active.
Otherwise, nothing is needed on the yellow wire.
Old Dec 10, 2006 | 07:25 PM
The1N_only's Avatar
Do you have anything that shows what kind of relay and how to wire it up for a WOT switch?
Old Dec 10, 2006 | 10:13 PM
JPJBC's Avatar
check the stickys in the nitrous section...they should have the diagram you are looking for
