Drag Racing Tech
Anyone have pics of oil accumulator setups?
Old 12-26-2006, 08:50 AM
383ss's Avatar
Default Anyone have pics of oil accumulator setups?
anyone running one of these or have pics of their setups?
thanks.
I searched and found very little.
Old 12-26-2006, 12:13 PM
ls1408cp's Avatar
I havent bought mine yet but I have done alot of research on this. Here is the fitting to plumb it straight into the oil galley http://store.summitracing.com/partde...5&autoview=sku
I dont know if its better to use this fitting or buy the adapter they sell.
I have seen them mounted in the car to under the radiator with an electronic valve.
Do you have a motor in the car now john?
Old 12-26-2006, 06:21 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,174 Likes on 763 Posts
Mike Brown had one on his turbo CE TA, see if any pictures are out there.
Old 12-26-2006, 06:42 PM
383ss's Avatar
I just sold my shortblock last weekend, starting to collect parts now for the build.
where exatly does that fitting match to go?
are you going to go with the moroso that summit has? if so, what size?
how exactly is all of it plummed?
Old 12-27-2006, 05:46 AM
ls1408cp's Avatar
It goes were the oil galley plug is right behind the alternator.
I am going to buy the accusump made by canton the 2 or 3 quart model.
I am not sure if its better to do it with the fitting in the galley or the spacer under the oil filter. There are plumbing instructions on cantons website.
Old 12-27-2006, 09:21 AM
383ss's Avatar
Canton LS1 kit:
#22-566 Accusump input adapter
#23-245 (two) .5" to -10AN fittings
#23-725 package of two hose ends
#23-705 (10ft) of high pressure hose
#24-006 3qt. Accusump
#24-270 electric valve kit for pre oiling applications "ONLY"
#24-271/24-275 epc valve kit for racing applications
#24-200 mounting clamps
is there anything in their parts list that is different that you found?? besides the block adapter at summit. the whole system looks very simple.
after a quick overview of the technical information, the canton definatly looks like a better design than the moroso, plus they have more options on sizes and valves.
Old 12-27-2006, 11:31 AM
7 Second Club
DRVETTE's Avatar
If you can, try to hook it up to the oil galley, only because it sends the oil straight to the needed source. Definetlly get the electric control unit so every time you start your motor youll have oil pressure. Your bearings will thank you.
Old 12-27-2006, 02:57 PM
383ss's Avatar
so the plug in the block behind the alternator will work fine, right?
Old 12-27-2006, 03:18 PM
Slow Z28's Avatar
just so i can say i learned something today...
what would be the benefit/purpose of doing this?
Old 12-27-2006, 03:50 PM
Race your car!
JL ws-6's Avatar
the oil accumulator, is a pressurized can that gets it's pressure from the engien running, initially it gets it from compressed air.
What it does, is supply the engine prior to startup oil pressure. You have a lever, or an electronic valve that will open, sending the oil in a pressurized tank into the oiling system, feeding all the bearigns and whatnot, so that there is no initial startup damage done to the engine. Alot of people with loose clearanced race engines like to use them because it prevents the startup damage that is more common with a loosely built engine.
Once the engine is running, the presure from the oil pump refeeds pressurized oil back thru a valve that the driver then closes off once the engine is up to temp, storing pressurized oil in the accumulator for use on the next cold startup.
383ss's Avatar
www.accusump.com
a lot of great info there. it will preoil the engine with pressure before startup and 'backup' to provide oil pressure if it ever drops momentarily. i.e. hard launching and cornering.
Old 12-27-2006, 03:59 PM
Slow Z28's Avatar
thanks guys.... lots of good info
Quick Reply: Anyone have pics of oil accumulator setups?
