Drag Racing Tech
Engine Package
Old Jan 2, 2007 | 12:53 PM
SoCal_T/A's Avatar
Default Engine Package
Ok so im going for low 9s to high 8s and im thinking either a 383 blown F1 or a 408 on spray. any thoughts on witch way would be a better idea?
Old Jan 2, 2007 | 12:58 PM
ATVracr's Avatar
Why not a 408 with an F1 ?
Old Jan 2, 2007 | 01:01 PM
SiL3NtXWS6's Avatar
or a 408 with a turbo? lol
Old Jan 2, 2007 | 01:55 PM
SoCal_T/A's Avatar
You think i could get low 9s to high 8s with an F1 Blown 408? should eleaborate on the car a bit. 2900lb 98 trans am with a 4000 stalled th 350 and a 9 inch. i just want 8s
Old Jan 2, 2007 | 02:19 PM
ls1mongrel's Avatar
408 with spray at that weight should get you there and will be the cheapest route.
Old Jan 2, 2007 | 02:42 PM
DRCE's Avatar
a 408 with an 88 is hard to beat
Old Jan 2, 2007 | 06:12 PM
FormulaFire's Avatar
how about a 408 w/ a F2..
Old Jan 2, 2007 | 11:34 PM
1QuickT-A's Avatar
IF you wanna go the cost effective route then go with the 408 and spray.. IF not, TURBO all the way!
Old Jan 3, 2007 | 12:14 AM
mrdragster1970's Avatar
6 & 8 Second Club
If you are truely at 2900 lbs a F-1 will put you in the 8's for sure. You only need ~800 HP. I weighed exactly 3000 and ran 9.31 in my slow car with 750 HP. A F-1 can make ~1000 HP. One issue, I don't know if that trans will last. I started breaking 350's at low 10's. That was many many years ago, so I know they are better, but 8 seconds better, I'm not sure. You better ask some experts 1st.
You will need a good chassis for 8's also.
Good luck.
If you ask me, I like blowers better than turbo's. The turbo guys seem to have a lot more problems, and had trouble being consistant that I've seen. I'm no expert, maybe all the turbo guys I've ran into were newbe's
Old Jan 3, 2007 | 12:19 AM
kp's Avatar
kp
I'll be in the 8s @ 3400lbs soon with a 346, .550 lift cam with single springs, stock pushrods, unported heads, LS6 intake/stock TB and a F1A. Nothing hard about it
Old Jan 3, 2007 | 09:24 AM
n2o's Avatar
n2o
Go with what you can afford. Maximize your setup (suspension, trans, etc.) or you will regret it.
