Drag Racing Tech
Calculating shift points...
Old Jan 18, 2007 | 03:13 PM
Old Geezer's Avatar
Question Calculating shift points...
Some time ago, I read an article in either, GMHT or Chevy Hipo magazine, on the formulaes used to calculate the RPM for shift points.
NE 1 recall this article, or remember which publication it was in??
Old Jan 18, 2007 | 03:16 PM
1SlowFormula's Avatar
If you have car craft then you can see those formulas in the newest one in an article about building your first drag car, or just go to the calculator in my sig to help get you close.
Old Jan 18, 2007 | 04:58 PM
RAMPANT's Avatar
I had found this, but have not tried it yet to see what it yeilds.
http://www.bgsoflex.com/shifter.html
Let me know what you think.
Old Jan 18, 2007 | 09:16 PM
ls1 joe's Avatar
I think the best formula is to run it at the track. Track times will tell you where you need to shift at.
Old Jan 18, 2007 | 10:37 PM
mrdragster1970's Avatar
6 & 8 Second Club
With an auto, I was told many years ago by a retired Pro-Stock guy to start at 1000 over peak HP. Clutch cars are depending on # of gears, clutch set up & size.
Track testing will always tell you the sweet spot, before a math formula as said^^.
Old Jan 19, 2007 | 12:17 PM
Bryan @ Speed Inc.'s Avatar
i have also heard that a 1000rpm past peak power is where you want to shift.
- engine builder from Burowski's in joliet.
Old Jan 19, 2007 | 12:29 PM
Old Geezer's Avatar
The article went into detailed calculations, to determine the correct point[s]. The calcs were, [they claim], much more accurate, than choosing a particular rpm, and shifting.
I wanted to go back to the article, do the math, then track test, to see if/any improvements were made, either way...
Thanks for the replies.
Old Jan 20, 2007 | 12:49 PM
Demonicbird00's Avatar
true but i think alot of us are on stock tachs. an theyre not all that accurate when running the 1/4. i rely on my shift light that i have programed at 6700 to tell me when to shift.
if your a m6 and you can shift fast then shift 200-300 past peak HP. if your an auto, id have it programmed to shift 100-200 past peak HP.
-brandon
Old Jan 21, 2007 | 07:05 AM
cablebandit's Avatar
it depends on tranny gearing as well. Performance trends Drag Analyzer has the computer pick the shift points once you put in dyno info etc
Old Jan 22, 2007 | 04:46 PM
Braunbeck's Avatar
I was just asking this on a local board, I wanted to know the shift points for my '00 SS with basic boltons, M6 and a 3.42's. I'm extremely new to the LS1's (just purchased on 1/19/07) and have driven the car a total of 100 miles. I wanted to see if I should be shifting prior to redline or a few hundred short. I'll look at the dyno graph that was provided by the previous owner and see if I can get a starting reference.
Good post, BTW
Old Jan 22, 2007 | 06:19 PM
Good post, BTW
what bolt ons do you have? are you tuned? id say w/out any info 6k but depending on tune and what not id say 6400
-brandon
Old Jan 23, 2007 | 09:03 AM
Braunbeck's Avatar
-brandon
Kooks L/T, high flow cats, Magnaflow catback, wires/plugs, LID/K&N, free mods.
No tune yet, waiting until I do cam.
