Drag Racing Tech
few pictures of my cars progress
Old 02-22-2007, 08:56 AM
  #61
LC
LC's Avatar
Originally Posted by ATVracr
Damn Justin that thing is SICK!
The rear set up look different, 4 link?
looks stock style with a frame mounted sway bar
Old 02-22-2007, 09:07 AM
  #62
ATVracr's Avatar
Upper and lower sway bar?
Old 02-22-2007, 11:23 AM
  #63
Race your car!
JL ws-6's Avatar
wheelie bar mounts maybe?
Old 02-22-2007, 11:50 AM
  #64
ATVracr's Avatar
This is the pic I was talking about.
I doubt the wheelie bar mounts on top of the rear
The bar above the rear looks alot like a chassis mount sway bar but its mounted on top, and there looks like there is going to be another sway bar mounted under the rear.
Old 02-22-2007, 11:57 AM
  #65
Race your car!
JL ws-6's Avatar
ya got me... I see the swaybar on the top, and initially it appeared there was gonna be a swaybar mounted off the bottom of the rear I agree. But, after putting the one in on top of the rear I'd suspect that the mounts would have been cut off for the old one, unless it's there so that the 2 can be swapped back and forth?
Smith, fill us in here, what ya got going on back there?
Old 02-22-2007, 12:03 PM
  #66
LC
LC's Avatar
yeah.. 4 link with the rear having provision for a torque arm...
and that in fact could be for wheelie bars, no point in powder coating a torque arm mount and un-used swaybar mounts on a rear that does not need them...
as far as i know, wheelie bars need 4 points on the rear.. 2 up and 2 down..
Old 02-22-2007, 12:26 PM
  #67
Mr Powell's Avatar
It's a Anti-roll bar. You can get the Wolfe "anti-swaybar" now that goes above the rearend. It is VERY common in Mustangs. It can be done on F-bodies as long as they remove the gas tanks. I was going to do that on mine, but I still had my gas tank at the time and couldn't afford to swap it all out at once.
Old 02-22-2007, 12:27 PM
  #68
ATVracr's Avatar
Makes sense I've just never seen a sway bar/anti roll bar up top like that thats why I asked
Old 02-22-2007, 12:29 PM
  #69
ATVracr's Avatar
Thanks I see the set up now.
Justin has all the new hot sickness
Old 02-22-2007, 12:38 PM
  #70
SMITH's Avatar
yeah that the wheelie bar mounts and my anti roll has been like that for bout 2 years now.
Old 02-22-2007, 12:43 PM
  #71
SMITH's Avatar
Originally Posted by Beaflag VonRathburg
Wow, I'm digging that a lot.
What made you decide to go with the 12 inch wheel over the 10 inch? I know it allows more contact patch, but what else? Did you have to move around the lca mounts and stuff? Those the wolfe offset lcas?
I have a set next to me right now. I'm trying to get all the details ironed out.
Thanks
i just wanted to be able to fit 12's. i have a set of 10's and 12's for the car. i bought the wolfe lower arms but we didnt use the offset bushings. if you look at the rear in the pics we took the relocation bracket and narrowed it up right much all toward the inside. then at the front of the arm we made our own offset bushings for it.
Old 02-22-2007, 12:44 PM
  #72
SMITH's Avatar
Originally Posted by JRcamaroZ28
looks real good, the only thing that jumps out at me is the front Strange shock set up. why not use the upper alum. spring mount that came with it? i dont think they are ment to be used w/ the stock rubber spring mount. if i recall someone on here had it set up the same way and over time it rubbed through the mount
thats the way that spring was designed to work. the top of the spring is made to fit back in the stock upper mount. its been like that for a year with no problems.
Old 02-22-2007, 12:47 PM
  #73
SMITH's Avatar
Originally Posted by ShiznityZ28
what front brakes ore they? I got the strange ones comming what fittings where on the callipers or was it just the femail tapped whole?
they're the strange front brakes. i think they came with the fittings to go in the caliper to -3an line. its been almost 2 years since i got them so i cant really remember.
Old 02-23-2007, 08:37 PM
  #74
SMITH's Avatar
intake
Old 02-23-2007, 08:41 PM
  #75
Race your car!
JL ws-6's Avatar
Nice looking plumbing job on the intake! It's up to par with the rest of the car for sure..
How big is the motor that it's going on? I assume bigger then the 347 you have in the sig... or are you really looking to bump that record to the stratosphere?
Old 02-23-2007, 08:43 PM
  #76
SMITH's Avatar
little 408
Old 02-23-2007, 08:45 PM
  #77
ATVracr's Avatar
What intake is that?
Old 02-23-2007, 08:50 PM
  #78
SMITH's Avatar
wegner motorsports
Old 02-23-2007, 09:01 PM
  #79
Race your car!
JL ws-6's Avatar
I've never heard of them... somethign you had made/modified to fit lsx heads?
Regardless, that thign goign on a 408, will result in 8 second runs I'm sure. Hell you'll probably be like everyone else and make over 100 hp more power on motor... and I'm sure it will like/take more juice hen the the old setup did.
Good luck with it, and thanks for posting pic's of such an asweosm buildup. I now have a new standard to try to build to thanks to you.
Old 02-25-2007, 04:37 PM
  #80
OutlawZ's Avatar
absolutely badass.... and here it is I thought my accufab was big.... then you go an pull that thing out
that's the 4150-4500 conversion plate on there no??? cause it looks like the manifold opening is 4150 and you stepped it up to 4500 so you could run the 2000cfm atmosphere reducer
Better tell everyone to hold their breath when you start that thing close to them... ain't gonna be no oxygen left when that accufab monster opens up...
