burnout question?
http://motownmuscle.com/fileshare/fi...052706_006.wmv
i have a LL, run on street tires with stock gears...
my burnout:
roll thru waterbox (all the way past), put it in second gear, set LL, punch throttle while letting out on clutch (all this happens at the same time), rev to approx 5500 rpms and hold for about 15 seconds, turn off line lock and roll out...it works for me. you will have to experiment with your burnout time ad your tire pressure.
on a DECENT track (not great) at a 3k launch i had enough traction to daed hook and break a driveshaft...at 3200 rpms i ran a personal best spinning a bit outta the hole...
you can do it without a linelock, but if you run on the track a good bit, a linelock will help you get more consistant. the tires im on are an off brand, and EVERY time ive recommended them ive been chastised for it on this board, but with a good burnout they get sticky, not greasy and slick like every other street tire ive done a burnout with...and i run them at rediculously low tire pressures (for a street tire) ON THE TRACK...
just my experience...hope it helps a little. for the low cost of a LL (you can find them cheap used), it will help ALOT...
-cam
but i keep on killing the car!
