Drag Racing Tech
HVAC control delete plate
Old Feb 10, 2007 | 08:51 PM
JUICED96Z
Guest
Posts: n/a
Default HVAC control delete plate
I have been searching for this and can't find it.
I am looking for a part number for the HVAC CONTROLS delete pannel if there is one. Maybe a 1LE part number since I am pretty sure the early LT1 1LE cars did not have heat either.
Car is a 96 so needs to be for 93-96 Camaros.
Old Feb 10, 2007 | 09:20 PM
Taubr Unit's Avatar
just make one out of some sheetmetal from your local home depot. Thats what i did and it looks real kickass.
Old Feb 10, 2007 | 09:25 PM
JUICED96Z
Guest
Posts: n/a
I am thinking about doing that for that and the HVAC plate.
Just buy a sheet and take it up to school and cut them out.
Bet I could find a scrap peice at school for the control plate.... aircraft grade sheetmetal
Old Feb 10, 2007 | 09:31 PM
Taubr Unit's Avatar
Heres some pics of my stuff. The control plate is just that and my blockoff plate on the fire wall was screwed in then sealed with aluminum tape.
Old Feb 10, 2007 | 09:39 PM
JUICED96Z
Guest
Posts: n/a
Cool, thanks!
Old Feb 10, 2007 | 10:48 PM
OutlawZ's Avatar
Send me your HVAC Plate and for a small fee i'll hook you up with one of these..... (not the gauges just the holes)..... you'd have to buy the gauges...
This is on a 95. show me a pic of your 96 plate and i'll make sure it's the same...
It uses the original HVAC controls panel with the guts removed so it looks factory....
And FWIW, the 1LE did have heat and all the normal HVAC controls... just didn't have A/C. The panel was slightly different cuz it doesn't have the additional switch position for AC. So they used a V6 camaro panel since AC was optional on V6's but standard on all V8's.... I know cuz I've got a 1LE
Old Feb 11, 2007 | 01:12 AM
Taubr Unit's Avatar
hey outlaw, what size gauges is that for?
Old Feb 11, 2007 | 01:56 AM
OutlawZ's Avatar
2 and 1/16 I believe...... the standard size autometers.....
Old Feb 11, 2007 | 05:05 AM
revtime's Avatar
Thats a great idea. I,m gonna steal it if you don't mind.
Old Feb 11, 2007 | 01:57 PM
JUICED96Z
Guest
Posts: n/a
LOOKS killer Outlaw....Thats the same.
Taubr, Was it east to remove that storage area under the stereo? Looks like it would be pretty clean with carpet in the car. I am thingking about doing that. You don't have to cut it off the center consol do you?
Old Feb 11, 2007 | 03:51 PM
OutlawZ's Avatar
Hell no i dont' mind... i didn't patent it I just know how to do it.... If you think you can pull it off by all means go for it.... just be careful cause usually you only get one chance
Old Feb 11, 2007 | 05:35 PM
Taubr Unit's Avatar
It was real easy. Its only glued on so i took a heat gun and heated it up and it poped right off.
