Drag Racing Tech
How to remove backing plates? Tried search nothing!!
Old Feb 11, 2007 | 04:53 PM
SLPSS99's Avatar
Question How to remove backing plates? Tried search nothing!!
Hey guys just wanted to know how to remove the Backing plates off my car, I am sure I could figure it out but would rather just know what to do so it will get done quicker!! I need to get them off so I can send them to Strange for the new rear!!
Dan
Old Feb 11, 2007 | 04:57 PM
patriotformula's Avatar
...you gotta take the axles out first... then just unbolt them from the housing.
Old Feb 11, 2007 | 05:04 PM
SLPSS99's Avatar
Ok this may sound stupid but I have never messed with a rearend, everything else on the car I have!!! But anyway how do you remove an axle
Dan
Old Feb 11, 2007 | 05:36 PM
JunkyardZ's Avatar
Pull the cover, press the axle in towards the pumpkin. Get a pair of pliers, or magnet and grab the c-clips. Once both clips are out, pull the axles straight out.
Old Feb 11, 2007 | 05:42 PM
1BADAIR's Avatar
have to remove the pin before you can push the axles in
Old Feb 11, 2007 | 06:04 PM
SLPSS99's Avatar
Got the first part but what are these Pins you are taking about and how do they come out? Thanks in advance guys!!
Dan
Old Feb 11, 2007 | 06:07 PM
LC's Avatar
LC
Just unbolt the rear cover, spin the carrier till you see a 8mm bolt.. take it easy on it or you can strip it..
Remove it, remove the "thing" that the bolt is hodling in place, then, push the axles inward and you will hear how the C-Clips fall into the housing.. then just pull the axle out..
Old Feb 11, 2007 | 06:11 PM
SLPSS99's Avatar
Cool thanks for the info bud!! Sounds easy.
Old Feb 11, 2007 | 06:18 PM
1BADAIR's Avatar
I think your axle has a wedge instead of a pin that the 8mm bolt holds in
