Light (but quiet) exhaust?
Thats what I have now.
So with a spiral flow off each collector, I obviously won't have an X pipe. Will that hurt performance at all?
Are people putting mufflers at the collector then running piping back to dump the exhaust? Seems having dump right in the middle of the car would lead to lots of exhaust fumes in the car. This is a street car.
Its not hard to drop my exhaust, maybe I could just make a "track" exhaust system with bullets off each collector. Lighter, plus better flow. Might have to try it, all I would need is 2 bullets and 2 turndowns.
Do I need any pipe between the collectors and the mufflers? Or can I just clamp the bullets right to the collectors.
This ******* gonna be loud.......
And you will be suprised.. it's not that loud. I used to run No muffler/no cats with an open Y pipe. Now that was loud...
Do you have any idea how it would compare to a TSP TD setup with dynomax bullet mufflers?
I would run a same size diamiter pipe as the collector and same or greater lenght peice of tubing before the muffler.
IE: 3 1/2 collector that is 8''. So you run 8''+ of 3/12 piping then to your muffler.
Thats how my setup is, it runs into magnaflow 3 1/2 oval mufflers.
Tony.
One question: I don't want to permanently attatch the mufflers to the headers (so I can swap to my other TD setup if need be), so how should I attatch the mufflers? My headers are 3", so the 3" spiral flows should slide right on. Would a band clamp work? I don't think a U-clamp would be smart, those tend to bend the pipes up pretty bad.
I got band clamps, hope my **** don't fall off on launch!
BTW, do you run your exhaust the same way at the track.
My muffler stays on like that on 1.25 60 foots and I can still pull the entire exhaust apart in 5 minutes. I got band clamps, hope my **** don't fall off on launch!
Here's the reason why i no longer run band clamps:
http://media.putfile.com/ByebyeMuffler
Hope it works...
KP, I had actually planned to do that already, but I was going to go through the clamp too. Your idea sounds better, and it'll keep the head of the screw from getting buggered up.
I would have actually lightened the car up had I not just installed the Spohn drag bar. Damnit!
Use a stainless screw also or it will rust quick and the head will snap off..Spohn sway bar weighs a ton, I know I have one, but it works and the weight is in a good place.
