Drag Racing Tech
Roll Cage paddin question
Old Feb 12, 2007 | 08:33 PM
LS1SpeedAddict's Avatar
Default Roll Cage paddin question
Is padding required on roll cages?
Old Feb 12, 2007 | 09:18 PM
Hrod382's Avatar
Nope. Some people just use as a preference to A. Keep their helmet from getting scratches and much more importantly B. Protecting their skull/brain in the event of a crash.
Old Feb 12, 2007 | 09:22 PM
The reason I asked is there are some areas where there should be padding but my cage so so tight to the body panels and what not it cant fit around the bar.
Old Feb 12, 2007 | 09:52 PM
skipperbisket's Avatar
if padding isn't required why does SFI rate some of the paddings?
Old Feb 12, 2007 | 10:06 PM
What areas are required to be padded?
Old Feb 12, 2007 | 10:20 PM
Hrod382's Avatar
It is required for like PS/FC/TF/TS/SC but in my IHRA rule book (can't find the NHRA) for Super Gas (9.90) it is not required. I'm under the assumption that once you hit 8.50's you need them (someone I'm sure has the exact number) but I've never had an issue passing tech running low 9's without padding.
Old Feb 13, 2007 | 01:06 AM
TwoFast4Lv's Avatar
Any place your helmet can hit must be covered. I use Jaz SFI spec
At least here in Division six
Old Feb 13, 2007 | 05:53 AM
JL ws-6's Avatar
Race your car!
you have to pad any area your head can hit as far as I know..... but I've also seen cars with funny car halo's and they weren't padded at all... so there may be some speed level when it is required.
I'm gonna pad around my head anyway, more for when I'm driving it around and don't have the helmet on.
Old Feb 13, 2007 | 10:58 AM
mrdragster1970's Avatar
6 & 8 Second Club
NHRA rule book rule 10.6
Roll bar or cage MUST be padded wherever it MAY come in contact with helmet.
Padding must allow a minimum of 1/4" compression or meet SFI Spec 45.1
It does not say anything about ET, it says any car with a cage or bar installed.
