Drag Racing Tech
Why larger diameter tires?
Old Feb 18, 2007 | 03:50 PM
James Montigny's Avatar
Default Why larger diameter tires?
I'm curious guys.
Why are some of you running 28-30" dia. slicks at the track?
It seems like that's adding a lot of rotating mass without any obvious advantage.
I mean, if I wanted more miles / rotation, I'd use a different set of gears right?
Taller sidewalls maybe?
Someone enlighten me.
Old Feb 18, 2007 | 04:22 PM
brandonppr's Avatar
the taller the tire the more touches the ground
Old Feb 18, 2007 | 04:37 PM
SLPSS99's Avatar
Originally Posted by James Montigny
I'm curious guys.
Most the time they run a deep gear 4.30s, 4.56, 4.88, etc so they run a taller tire so they don't run out of RPM before the end of the 1/4 mile.
Dan
Old Feb 18, 2007 | 04:40 PM
Top Fuel's Avatar
some people use them because they are running large gears to match their stall and cam and they are needed to go through the traps at the appropriate rpm.
others use them as a band-aid for a poorly set up suspension, the taller tire is easier to hook and more consistent
Old Feb 18, 2007 | 04:41 PM
ATwelveSec02Z28's Avatar
I run the 28" tire for 2 main reasons... like brandon said, the larger tire has more contact on the ground, and the more sidewall takes a little more shock from the clutch dump.
