Drag Racing Tech
QA1 coilover question?
Old Mar 1, 2007 | 10:22 PM
bigsticksupra's Avatar
Default QA1 coilover question?
Hello everybody. I am getting a set of QA1 HAL coilovers for my car, but in the F series. I was wondering if this was any better for drag racing when compared to a regular bilstein and prokit combo? I don't want the R series since this is the car i use as my daily driver. Also what spring rate should i get? Thanks.
Old Mar 2, 2007 | 09:55 AM
Matt D's Avatar
Retired Street Racer
The "R"s are better for drag racing as they have fixed firm compression & adjustable extension. I have the "R"s w/ 275lb springs on my 99 Z and I daily drive the car everyday. (Set at the softest setting all of the time too)
Old Mar 7, 2007 | 04:30 AM
how is the handling of the QA1 R's when they are firmed up? can you actually do any hard cornering or no?
so the QA1 F series is no good for drag racing?
Old Mar 8, 2007 | 08:12 AM
bad2000z's Avatar
I have the F series on my car now, but will soon be switching to R series. With the F series set at the lowest setting the car comes up fast in the front, but then takes a nose dive. Having the fixed compression will help transfer weight to the rear tires, and keep it there.
Old Mar 8, 2007 | 08:31 AM
SiL3NtXWS6's Avatar
i have the F's and on the lowest setting the front end end comes up FAST. I run them at 8 when i wanna go take some turns fast.
Old Mar 8, 2007 | 09:44 PM
cool guys, Thanks! I am getting a used set actually for a pretty good price (QA1 HAL F series) i think the QA1 and HAL is the same deal correct? but yeah, how would i be able to tell if they are in good condition? The guy says they've been on the car for 20k miles, no leaks, etc. What else should i look at to see if the shocks are in good condition? Thanks
I would get the R's but i daily drive the car and i like taking some corners hard occasionally so i guess i have to find a good balance between drag and good handling. I guess the F series is as good as its gonna get for both? Maybe i'll try some different front springs..i believe he said he had the 300lb. spring in the front coilovers..
