Drag Racing Tech
New setup! launching rpm?
Old Mar 3, 2007 | 11:16 PM
Bonertee's Avatar
Default New setup! launching rpm?
I'm going to the strip next weekend. I just finished installing a Motive 4.10 in my m6. I have a SLP lid with k&n, long tubes with ory, ripper shifter, and now 4.10 gears. Hopefully I will also have my 315's on the back by then which will also be street tires. The last time I was at the fun park, I launched about 2000 rpm with best of 2.1 60ft. which was before the long tubes and gear. That was on 16 x 8 stockers with bfg street tires. You guys have more experience in this that I do. So my ? is, what rpm do you think I should launch at and what 60ft. do you think I should be around? Any and all info will be appreciated.
Old Mar 4, 2007 | 08:33 PM
Bonertee's Avatar
Anyone?
Old Mar 6, 2007 | 01:50 AM
93camaro_zzz's Avatar
I pulled a 1.86 60' on my 275 michelin pilot's with 100% stock suspension, and full weight (3580 w/o driver, I weigh 160). I dont believe in clutch dumps, I ride the clutch out. Obviously not excessivly to heat the hell out of it, but I launched at 5K on that run, and didnt spin. See what I mean? I think it helps with staying in the LS1 powerband, which is sweet BTW. Good luck.
Old Mar 6, 2007 | 08:02 AM
Bitemark46's Avatar
315 street radials or 315 drag radials? If they are regular radials you are still going to have to slip the clutch out. For best results pre-load the drivetrain lower the tire pressure a tad and disconnect the front sway bar. Even though you have a bigger tire you adding 4.10's actually will make it harder to launch that before. So your launch rpm my be the same or even lower. -Mark
Old Mar 6, 2007 | 05:32 PM
Yeah, the lower gear will put more torque to the ground in first, but 2000 rpm is extremely low to launch at. I would do at LEAST 3k. Your making like 2.5hp at 2000rpm. jk Gotta let it breathe!
