Good 60ft techniques?
I did a good burnout when i cut the 2.009 and the tires stuck stalling the car to like 1700 and then I flooring it. Still i think my car is supposed to be in the 12s but its not because of bad driving maybe? What do you guys think? They're some guys cutting better sixties with hardly any suspension work. How do you cut those low 60ft. times?
I see you have a short TA. I think you may need to adjust it some to get a better hook and move
the only reason i have not break stalled the car higher is because i dont want to roll through the lights. its not so easy watching the tree and looking to where your rpms are at the same time. the tires start to break loose at 2500.
i think your stall isnt a 3000...in my freind z bone stock with a 3200 stall and 3.23 he cuts 1.8 on street tires...
i dont know why my mickeys would break loose when doing this even after a good burnout. but like i said my first run was the best i pulled a 2.009 sixty and thats with the tires actually sticking on the launch. im really comfused as to why my 60s are so low. people are cutting lower 60 with a lot less.
