How to delete and properly remove all ABS/TCS???
I been doing a search and came up with no information on a step-by-step on how to pull my ABS and TCS. I need to know what all to pull and what I will no longer need. A 9 inch with no TCS and ABS is going in, as well as a SJM ABS and Line Lock kit. I would just like to take the time and pull all of this crap out. Please post If anybody has a link or any info on how to properly remove all of this.
Thanks,
Thanks,
Originally Posted by JEB99TA
How much weight does it net you? How come you're pulling it out? Is it just for weight gains or you simply don't like haiving the features on your car?
Originally Posted by black_z
Its somewhere between 15 and 20 lbs after everything is removed. I will weigh it this week when I install my SJM linelock/delete kit.
Directions are very detailed with picturials as well. If your kit includes the LL kit, detailed directions with a full schematic is included! If customers have any concerns or confusion, we are only a phone call away.
Weight removing is quite a bit and probably one of the best bang-for-buck modifications. Amount of weight removed depends on what model i.e. LT1/LS1 or if the customer has traction control etc. On average an easy 15lbs is removed...it can be as great as 20lbs once again depending on variables listed.
For the past 11 years our LL/ABS delete or just LL kits as always are in stock and ship within 24 business hours...many times same day!
