Going to the track for the first time, few ?s
Questions:
I'm running goodyear GS-C tires, should I lower the pressure or just keep em at 30psi?
Water-box... it seems not many people go around the water at Atco, seems kinda difficult to do actually with the limited space around it, any advice about this would be appreciated.
Launch, not really sure what is best to minimize stress, not spin, and get a half-way decent time, tips here are welcome.
Any other advice about the track, procedure etc you have would be great, thanks.
Questions:
Drop pressure in the tire it will help alittle.
Go around water as much as possible the least amount of water you can get on the front tires the better. Your rear will follow the front and the more water you track in the rear tires path the less traction you will get.
If you are in a stock rear with a 6spd you are on borrowed time especially at the track where traction will be at its best for any given set up. Come out soft and roll onto the throttle. Then continue to raise rpm's and roll on harder each time untill you get to the threshold of breaking loose, then back down to where you held the best.
Remember you will not get the best numbers out of your car in one trip to the track.
Good luck,
Dave
