Cage guys inside
I am supposed to get my car back from the cage install on Saturday. It got a WOLFE 10 point with harnesses, passenger air bag delete, HVAC box delete.
They disconected the battery as I was leaving their house (both tig welders by trade and do cages on the side) and got to work. Put everything back together and the car will not crank or start. No fuel pump, just lights.
He said when you go to start the car its like there is no battery in the car but everything else like the lights work.
Me and a buddy said it HAS to be the VATS and its not connected right or something because they checked all the grounds and connections that they could see with the dash on.
We say VATS because nothing works engine related. They even replaced the ignition control module thing.
I told him to call up WOLFE and a few other speed shops and see what they say but I am thinking something got screwed up with the VATS.
The little resistor is still in the ignition key.
Ideas?
They asked if I still plan on getting it at around 9am on Saturday and I said yes
. I think its the purple wire on the starter but whichever it is.
I found it and tapped a wire into it. I turned the key to the run position and touched the wire to a hot for a second. It turned over and started. I had to start it that way for a few days then it went back to normal. I had problems with it every now and then and race it all the time and when it happend it would be at the track. so I wired a push button to it so that if it happens at the track I can bypass it instead of sitting there no being able to race because of the stupid VATS. btw it was turned off in the computer but still caused problems for me.
so if you wire it to that and it doesn't work I don't know
6'2 and 210 pounds make getting in and out with bent door bars a PAIN!!!!!!!!!!!!
Only think thats weird is they mounted the over shoulder harnesses to the floor, not the bar...
