Drag Racing Tech
PA Racing Manual rack???
Old Mar 22, 2007 | 03:24 PM
slowredz's Avatar
Default PA Racing Manual rack???
Anybody used it? How is the steering?
Old Mar 22, 2007 | 03:43 PM
Billy the Great's Avatar
unless it is a kit designed to bolt onto a 4th gen then i would just get the Madman setup. Had a buddy try to use a generic rack and it ended up costing him way more than what Madmans kit goes for. Sure the rack itself is cheap but its all the little stuff that adds up and kills the savings
JMHO
Old Mar 22, 2007 | 06:39 PM
slowredz's Avatar
It is a kit made specifically for F Bodies.
Old Mar 22, 2007 | 07:49 PM
skipperbisket's Avatar
Josh, I would assume it is fairly similar to a Madman rack in which case as long as you're running skinnies up front you're fine. What is the cost of the PA setup?
This is my Madman rack using some "custom" mounts rather than what comes in his kit. Also, his setup comes with the right steering shaft to just bolt right in, drill one hole and you're ready to go, just make sure you clarify when you order (if you did go that route) that it is an LS1 car as the shaft differs from an LT1 car.
Old Mar 23, 2007 | 01:05 AM
slowredz's Avatar
The PA is almost $200 cheaper for their kit...
Old Mar 25, 2007 | 10:02 AM
ATwelveSec02Z28's Avatar
I have the PA Racing K-member with Pinto style mounts, and the manual rack. The kit is pretty good but getting the geometry straight can be a pain. As far as I know PA is not making a setup like MadMan where it mounts to the OEM mounting locations.
Old Mar 25, 2007 | 04:37 PM
cainsw's Avatar
How big of a deal is it to put one of these on and get it set up right? I'm refering to the Madman setup
Old Mar 25, 2007 | 08:18 PM
ninetres's Avatar
I will let you guys know. I am having one installed in a week or two. Hope it isn't that much of a PITA.
