Help the slowest TA ever!!
reaction - .9582
60 ft - 2.130
330 ft - 6.254
1/8 ET - 9.488
1/8 MPH - 76.84
1000 ET - 12.2349
1/4 ET 14.5932
1/4 MPH 95.30
(Mustang #'s)It was about 75 degrees and overcast, a little humid, and i DO have 3 month old stock size tires on the back so theyre pretty sticky. I was stalling the damn thing at a high enough RPM that the tires were starting to move before launch sometimes. After launch id just stick the pedal to the floor all the way through the traps. Only things i could imagine could be the problem are fucked up o2 sensors, a problem i know i have, although the car seems to run fine at wide open throttle. Only other possibility i can think of is a stretched out throttle cable, although (once again) i do believe that it opens all the way. What do you thin my problem could be SERIOUSLY!? And before some smartass asks YES THE PARKING BRAKE WAS DOWN.
Just do a bunch of general maintenance to make sure none of the little parts are worn. Do plugs, wires, fuel filter, air filter, etc...
Headers could also be screwing up your tune, so I'd consider adding that to your list of things to check as well.
Derek
