ET Drags or Hoosier????
18150 28/10.0-15 D06 compound Hoosier slicks
Well, my 28/12.50-15 ET Streets are showing the bands now, so I need a new pair. The car sees little to no street use (the cops are cool around here, and would have a better reason to pull me over than for slicks...lol). Just wondering what other people have used and liked. Car couldn't hook on the ET Streets, but I didn't get to play with suspension that much. And the price of the Hoosiers are pretty good ~150, ET Drags ~160, ET Streets ~170. Dunno, who has tried what and what 60' were you running? Thanks.
Chris
Chris
The W's definitely need a 10" rim, the others don't have to, but prefer that width rim. Good luck. Take care. Dave
Hoosier 18150 28/10-15, 10"tread, 11.7 section, D06 compound, 22 weight, $156
ET Drag 3055 28/10.5-15, 10" tread, 11.7 section, M5 compound, 23 weight, $160
ET Drag 3055W 28/10.5-15, 10.9" tread, 13.1 section, M5 compound, 26 weight, $195
ET Drag 3057 28/11.5-15, 11" tread, 12.9 section, M5 compound, 26 weight, $190
Also, these are going on 10" wide draglites. I've done alot to the innerfender to get the 28/12.5-15 ET Streets to fit, section on them show to be 12.6". Surely I could get the 3055W's to fit, but the 3057's are cheaper, same weight, same tread, narrower section, and same compound. Might go with those. But still kicking around the Hoosiers, if I can get my suspension setup right.... Anybody have anymore info or experience with any of these? I greatly appreciate any input you offer, thanks again.
Chris
Chris
Chris
used both, my size was 29 X 10, so a touch bigger.
Hoosier worked better and lasted longer.
I was also learning more & more about my double adj shocks,
so maybe it was a learning issue.
Good luck with the M/T, hope u do great.
From what I have been told get the car on level ground and take the measurement of the Driveshaft and the bottom plate of the TQ and subtract the 2. I think you should shoot for around -3, but it depends from car to car??
Btw I ordered a New GM LT4 starter I think that will fix the problem
Chris
Chris
