Drag Racing Tech
Optimized MT ET Drag
Old Mar 26, 2007 | 10:15 PM
aNuBiS's Avatar
Default Optimized MT ET Drag
I tried asking in the wheel/tire section but apparently these kinds of questions dont get answered there so I am trying here.
I tried searching around, but couldnt find anything consistent.
Those of you running Bogarts or similar 15" wheels, what size MT ET Drag's or similar slicks are you running out back (height/width plz) and same with front runners.
I have a 3.73 gear and an A4 trans. Looking obviously for the best size optimized for the drag strip.
Much appreciated
Old Mar 26, 2007 | 10:33 PM
SiL3NtXWS6's Avatar
max power? Turbo, N20, or NA?
I run a 28X10.5S with 3.73s, M6
Old Mar 27, 2007 | 07:12 AM
gator's 99TA's Avatar
what is your mph goal? for most 28x10" slicks, an A4 needs a 4.10 gear. what is your converter?
Old Mar 27, 2007 | 10:23 AM
aNuBiS's Avatar
N/A (however I do have nitrous, but dont use it often)
Not sure on max power yet
Old Mar 27, 2007 | 10:26 AM
aNuBiS's Avatar
I got a PT4000
Would a 28x10 be ok with a 3.73?
Old Mar 27, 2007 | 02:59 PM
if you plan on trapping more than 125 yes.
Old Mar 28, 2007 | 12:44 PM
Smokinstorm's Avatar
Old Drag Racer
I've currently got the 26.4" x 10" x 15" Hoosier slicks mounted on my Bogarts with a 3.90 gear. I need a little more gear and also a little more traction so I'm switching to a 4.30 gear/spool and a 28" x 10" x 15" Hoosier slick. I'm running the same PT4000 converter and plan on trapping close to 130 with the gear/tire change as long as the weather holds out.
Old Mar 28, 2007 | 03:37 PM
aNuBiS's Avatar
Let's say I stuck with the 3.73 gear, what would be the best tire possible for the highest trap speed and/or to keep me in the RPM range I want to be in while crossing the 1/4 mi
Old Mar 29, 2007 | 06:00 PM
aNuBiS's Avatar
I dont have the ability to do the math to figure this out, would really appreciate the help from the guys on the board!
Old Mar 29, 2007 | 06:49 PM
bro,. there are people that want to help you but notice you are not answering any of the questions people asking?
what is your power level?
what is your expected trap speed?
what is your expected ET?
what is your shift points?
there is NO SUCH THING as a best tire size for every combo.
Old Mar 29, 2007 | 07:36 PM
1SlowFormula's Avatar
Use the calculator in my sig to help, there isn't one directly for you questions but you could use the optimum gear calculation and see what tire size gets you closest to 3.73 for the RPM's and Speed you want to cross the line at...
Old Mar 29, 2007 | 09:53 PM
aNuBiS's Avatar
Very helpful thank you.
Wow, says that if I want to trap approx 121mph with approx 3.73 gears, I need a 26" tire, but I would be crossing the line at approx 6000rpm.
I would most certainly need more gear
