Am I setting myself up for failure?
I already have prostars (15 x 8) with a 275/60/15 MT Et street radials mounted on them. I am going 9" and 4.33 or 4.56 gear with a moly UMI torque arm. Already have billingsley LCA's and Comp Engineering rear shocks. I will also do driveshaft, afco front shocks/springs and LCA relocation brackets at the same time as the rear.
Car is daily driven to work and back (only a few miles to work) and on a few longer trips (180 miles round trip) a year so I need a tire that can handle some rain. I hit the track about twice a month during racing season and don't want to change tires at the track.
So my question
1.Will the ET Street radials get me to 1.7X or lower short times with my setup?
2. If I plan on spraying around a 150 shot will I even have a chance of hooking or should I just build an all motor car? This will determine if I go to a 4.56 rear gear.
3. Is there another tire that will hook better that I can still daily drive without too much worry?
Thanks for the help in advance.
Marty
Chris
Screw it, I guess I'll just have to go TH400 and 4000 stall.
Marty
Chris
i think with your set up you should get the 4.56's and get a set of 28" or get 4.10's and go with some 26" tires. i personally say with the 15x8 rim go with a smaller gear and smaller tire but run a regular et street bias ply tire or get some slicks for the track only.
Chris
I'd get yourself some full slicks for the track, 26 of 28 inch, whatever you choose to run, and get yourself another set of rims and put a regular stret tire on for daily use. They are alot cheaper, last about 100 times longer and if you do get in an accident, get pulled over whatever, it will be one less reason for a cop to harrass you.
I have a set of bogarts I run at the track, and a set of stock C5 z06 wheels I run on the street... I'd suggest something like that, or at least another set of rear tires/rims.
