The Motor is now installed....Pics within
I really like how all the wiring is hidden. That looks like it took a lot of time. What's the bottle mounted in the front for? Chutes / fire system? [/QUOTE]
The tank/bottle up front is for the Accusump (engine oil pressure). If you dont know what that is, it holds 3 qts of the engines oil under whatever pressure the engine is running at, and if the motor loses pressure for a second it will dump all of its oil back into the oil passage way
The rest of the pictures not uploaded can be found here...
Link to rest of Pictures
And the gray hood has now been painted
and where on god's green earth did you get something to convert your radiator outlet to a big *** AN fitting???? that is BIG PIMPIN....
Mine is an LT1 but it will look pretty similar to this once in the engine bay (with the exception of the motor plate) I really like how you did the radiator standing straight up by cutting the center framerail out.... how does it mount at the bottom???? i can't really see it too well...
Here are pics from when I built that stuff last winter. Let me know if you have any questions.....
