Drag Racing Tech
Off the line with PG
Old May 1, 2007 | 05:52 PM
evojuiced's Avatar
Default Off the line with PG
I have a JW Promod Powerglide leftover from my aborted 95mm turbo build , and want to use it in my 408 Nitrous car (since no-one wants $4500 PG)
My question is with a 4.10 gear & 29.5" tire will the 1.8 low gear be to much to work properyl.
Car is a 14.0:1 408, ET 265's solid roller, on a dual stage Kit 150/100.
30XXlb race weight.
Anyone see it having any problems getting of the line Properly?
Old May 1, 2007 | 06:00 PM
MADMAN's Avatar
LS1Tech Sponsor
Spray the **** out of it and the glide will work killer.
__________________
www.madmanandcoracing.com
225-343-9029
Old May 1, 2007 | 06:14 PM
evojuiced's Avatar
would you recommend 200 of the line, then another 100 progressive up top?
Motor is built for serious abuse, o-ringed block, ET heads, 9/16 head studs and Nitrous Specific Pistons)
How long a Wheelie bar should i use?
Old May 1, 2007 | 08:03 PM
mrdragster1970's Avatar
6 & 8 Second Club
My slow car is 3200lbs 4.10, 29 X 10W Hoosier, 9.30 on nuts, 8.50 on 175 shot with a Coan Top Dog and mine was only $4250.
Use a 84" bar.
Oh, I just happen to have a set 4 sale. ($200)
Old May 2, 2007 | 02:05 PM
1fastWS6's Avatar
Do you keep your turbo in the fridgerator next to the milk and soda??
Almost anyone with a good amount of HP runs a 1.80 glide. You won't have any problems with it being "too much".
Craig
Old May 2, 2007 | 02:13 PM
evojuiced's Avatar
Use a 84" bar.
Thanks guys.... an 84" bar?????
don't think that'll make it into the trailer...
Yeah well JW i learned is a bit more expensive than most, it does have a promod 10/6 clutch drum, vaso pump, etc, etc..... they said it's undestructable
Old May 2, 2007 | 02:36 PM
1fastWS6's Avatar
Undestructable.....that unpossible. JFWY
Old May 2, 2007 | 02:44 PM
evojuiced's Avatar
Owned by the Inglish language (j/k)
Old May 2, 2007 | 08:06 PM
JL ws-6's Avatar
Race your car!
sonic snake is running a glide in his camaro, and he's only running a little 346 with a 150 hit. Car runs 9.5 to 9.6, and was 60 footing in the 1.3x range with goodyear drag radials......... the glide will be fine.
Old May 3, 2007 | 12:57 AM
6 & 8 Second Club
Try a 102" bar?!?!?
Coan claimed 2250-2500 HP when I bought mine, I would hope any of the brands $4000+ glides better be pretty damn strong. I was just giving you a little jab, nothing meant by it. Good luck.
Old May 3, 2007 | 09:49 AM
evojuiced's Avatar
Try a 102" bar?!?!?
the weren't directed at you, they were at JW...
I really appreciate the help guys
