Mini Tubbed and Small Set of M/T DR
Your car looks awesome, although I am a little confused on your calculations of 60hp per lb of boost. 890rwhp at 14 lbs(almost atmospheric pressure) so 1/2 of 890rwhp= 445hp on motor another 445hp from the boost. 445hp/14psi=32hp per psi.
Either way the car is prestine, it looks so good I almost wouldn't want to race it.
On the 2 other set-ups. If you want to fit the tire inside the fender well - just by my experience - the 12" will not fit unless you cut apart the fender itself. I didn't want to cut the fender itself. It seems that that 10" work. 5" or 6" you'll have to decide. My overall 6" works. The 315's are bigger than the 325's according to M/T website.
David
David
My motor only had better make more than 445
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks for the comment on the car. It was built to race. I can't wait to hit the track again. Soon hopefully.
David
David
David
You are saying they rubbed on the actual fender?
if so on the top or the front or back?
Originally Posted by brandonppr
Could you have rolled your fender and they fit?
No they don't rub any where.
Any bigger rim, and I would not have been able to lower the rear-end over the tire. I still have a little room for a little bigger tire if I want to. I think for now a tire that is 30x11.9 is good enough.
David
I run the Wolfe mini tubs, Centerline 15 x 10 wheels with 5" BS, Wolfe off set control arms with 325/50 MT's on a 9" narrowed 3" per side and everything fits perfect, close to the control arm but managable.
same here on a S60, but my LCA's arent offset yet... no need yet....
The 315's and 325's are pretty close to each other.....
Anyone tried the 295/65's??? there a 30" tall tire.....
Looking awsome david...... when's opening day up there?????
Sure wish someone would make a 15x10 with 6" B/S. Just nothing out there - except Bogarts which I love but can't afford a 2nd set.
3 weeks ago - the SS still is not ready for the track
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
David
The 295's are 30" with 10.9 tread about an inch narrower than the 315. The 315's are 30" x 11.9; 325's are 28" x 11.6. All 3 seem similar.
Soon, hopefully soon.
David
David
Holeshot wheels will make whatever backspacing you want.
Here is a pic of mine...325/50's, 9 inch narrowed 3 inches per side, 15x10 w ith 5 inches of BS, chome moly control arms,and a mini-tub, the LCA's arent that close to the tire, about a 1.5 inches. What is close is the LCA mounting bolt on the rear end, real close to the wheel itself.
[IMG]
![](http://img519.imageshack.us/img519/3574/progress010oe6.jpg)
David
#32
David
David
I might have to try those 295/65's since there narrower then the current 325's i have now..... maybe i say LOL
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Get it done and get to the track man.....
#33
OWN3D BY MY PROF!
Fenders are rolled.
David
David
Or was it a problem of the outer edge where the sidewall and the tread meet rubbing on the fender if you lowered it down.
If you can't tell I'm trying to figure out what it's going to take to fit some 15x12s with 325/50/15s.
#34
Originally Posted by Beaflag VonRathburg
I've noticed your car sits relatively low. The major problem then was the heighth then? With the 325/50/15 only being a 28 inch tall tire do you think the 15x12 would work?
It's the problem of the outer edge where the sidewall and the tread meet. The inside will fit, but the tire would rub the edge of the fender. Not by much, but close enough not to want to chance it. The edge of rim is just inside the fender well. Add the tire.. not going to work. I did not mount the tires, so I could return them. Just eye-balling it, it wasn't going to work. the 15x10 are fine.
David
#36
lookin good navy
do you know if thunder will be open the first weekend in june i need to go and thats about the only weekend i got open.
when are you gonna hit the track. i hope to see you there.
oh yeah do you have the web site for thunder valley? thanks man
#38
CamaroKid.. Not sure when we'll be at the track. Here's the track's link, it has the schedule on it.
http://thundervalleydragways.com/
JPMuscle. No other pictures right now. Lately we have only seen rain.. I'll try to get better pictures soon.
David
David
