Basic M6 Launch Facts Illustrated
Also green is throttle position correct? My Z is an A4, but im just wondering, why are you letting off the throttle between shifts? especially with a strong rear? wouldnt you just want to leave the throttle on the floor and be quick with the clutch? Not being a wise *** or anything, just curious of the reason...
Thanks
I will be trying a slick soon as this should help as they will hase out while pulling where as the drag radial once spinning spin bad
Look at 6speedrebuilds in car vids and the car is yanking the wheels, running single digits and it sounds like it's "bogging". Same with FMS's car (long time ago).
Second run I dropped the tire pressure from 26 to 21 and launched at 3500 trying to slip the clutch out and got real bad wheel hop, so I let off. Third run missed 3rd.
Then on the 5th run I launched with a little clutch slip at 4500 and it hooked hard. It only went a 1.80 60', but atleast it didnt spin or fall on its face.
I'm anxious to get some more weight off the nose, get a tq arm in it, and go play.
I will be as consistent as an automatic. It can be done. (Hey I've had an auto, so flame away A4 owners
) The Best V8 Stories One Small Block at Time
Thanks for the info on the software!
Good 1/4 times and nice 60' btw!
On a side note, No offense, but those shifts take you for ever. Each shift is almost a second, that is almost 2-3 seconds your car is NOT under power. Take your second run for instance; you can see the wheel spin in the MPH spike on the 1-2 shift, but you can also see that your MPH actually decreases between shifts. You are loosing 0.5 to 0.7 seconds in your 1/4 ET's on your shifting alone. I'm not trying to be a jerk, I just think that I have a bit of experience driving 6spds and am only trying to help.
For you're own sake, you should look at the same graph, but also turn on the line for Throttle Position, after the launch it should stay steady at 100% until you cross the line. It is obvious to me looking at that graph that you are letting off during those shifts.
I don't have the files, because it was not my data logger, but my shifts average from 0.10 to 0.15 seconds, with 100% throttle position across the board.
