12v vs 16v systems
6 & 8 Second Club
We switched to 16 Volts because it's stronger and you will start easier with less than a full charge, especially when weather or oil downs is making us hot lap rounds. I'm a big fan of more power to the fuel pump, N2O & starter the better. If starting a new project it would be the way to go, no second thoughts. If I had a 12 Volt system that works fine I probably wouldn't buy a new battery, alt & charger just to have 16 Volt set up. Like Mad Man mentioned, everyone I know says an alt is a must have with all the modern stuff that injected cars have, and then you can run one battery.
6 & 8 Second Club
I have full drag only cars. My experiance is with them, no stock parts of any kind. Wasn't thinking about lighting, or computers, good advice.^^^^
Resident Racing Jerk
isnt there a battery that has 2 posts on it? one for 16v and one for 12v...
also, if im not mistaken, the f.a.s.t. systems will handle up to 18v or so without going nuts about it.
running a 16v battery without an alternator, the lights and stuff will be seeing around 14-15v or so. no biggie there, thats just a tad more than they would see with a 12v alternator charging at 13.8.
Originally Posted by Phil99vette
Can you run a 12 volt alternator with a 16 volt battery to keep the voltage under 18?
6 & 8 Second Club
It says very loudly & clearly in the 16V paperwork, do NOT use with a 12V alt.
The 3 post bat is the best for a car with stuff that will not handle the 16V.
You won't have to worry about add on box's going bad on you.
Which alternator are you guys using? Is a 16volt to 12 volt step down box really necessary? How fast will it burn the head lights out?
Phil
Phil
Originally Posted by Nine Finger 02 Z28
Everything on my car is 12 volt but the alt and the bat.and it is fine and works good.I have the 16 volt to 12 volt step down box but I am not using it.
I was having problems with the BS3 and the 12volt with a 13.5:1 CR motor. On start up it was popping back through the intake and the voltage was under 10volts on start up. I talked with Madman and he said that the 16v would fix it. Sure enough it did. Starts up perfect everytime with no issues.
