Oil pan removal question
I'm thinking of swapping oil pans over to a Moroso or Stef's deep pan with a trapdoor, but I'm just seeing if I can do it w/o getting my engine hoist out and also having to pull the balancer and front cover. If I do, I do, but...
Thanks for the assistance. BTW, I did a search on "dropping oil pan" and "oil pan removal" and nothing much came up. Take care. Dave
By the way, do you know the part number to the Moroso or Stef's deep pan with a trapdoor. We may need to go to one of these pan's(see sig)!
Coach
Coach
On the Stef's, you just call them and tell them what you want. Since you are running a tubular k-member, they can and recommend adding the sump deeper up to the point it would be up against the k-member. Their's and the Moroso (PN 21150 with special pickup and screen) are meant more for Super Stock with a modified stock k-member. They are nice, but don't have as deep of center section nor do they have kickouts that you could run if you wanted.
Either way, good luck. Take care. Dave
