QA1 "R" series users inside please
i have these R series turned all the way to the loose setting, dial all the way left, and the front end of this car just doesn't seem to come up at all when i nail it. with my old F series i used to be able to pick the left front tire up off the ground by rockign the converter a couple times from a roll..these R series the front end like hardly moves. i put the dial all the way to the right and it was worse obviously..
any input on this? i have 300 lb springs on the car now.
I'm not a fan of QA1 products, but you might want to have them looked over by the manufacturer.
How are they at the track? Same?
fwiw I have a lw battery and some stuff out of the engine bay, but the bumper support all that is still there, alum motor. The nose is probably similar weight maybe a little heavier then your car is.
Im upgrading to the R's this summer.
seriously my old F series would completely unload the front suspension if i just flashed the converter and saw a few lbs of boost..do that a couple times quick and the left front time would be in the air from a roll. these things don't seem to come up much at all..
haven't been to the track yet with the, we'll see..
