Drag Racing Tech
Solid motor mount question
Old May 7, 2007 | 04:11 PM
ls1king000's Avatar
Default Solid motor mount question
I have spohn Chromemoly motor mounts and need to lower the motor. Can I just cut one of the plates off, then weld it back on at the new shorten length?
If I do this equally to each side, will this lower the motor properly?
Old May 7, 2007 | 08:15 PM
mrdragster1970's Avatar
6 & 8 Second Club
What are you going to do about trans & driveshaft??
Old May 7, 2007 | 09:38 PM
ls1king000's Avatar
I only need lowering like 1/4" for the intake elbow to clear my hood. I don't want to cut my hood.
Old May 7, 2007 | 09:40 PM
Mr.MartyStone's Avatar
Yeah but the tranny is directly connected to the motor and will need to be accomodated for if you drop the motor 1/4"
Marty
Old May 8, 2007 | 12:34 AM
smoknta's Avatar
Easy way to drop the tranny would be to put some shims or spacers on top of the crossmember.
Old May 8, 2007 | 12:45 AM
brandonppr's Avatar
Wouldn't the same thing work for the K member?
Old May 8, 2007 | 08:28 AM
jldak318's Avatar
this sounds like a bad idea to me. cutting and welding on motor mounts dont sound to healthy to me. just my opinion.
Old May 8, 2007 | 08:32 AM
ty_ty13's Avatar
7 Second Club
as long as your a compitent weldor then i see no problem with it aslong as you take car of the chain reaction of events that will follow..
Old May 9, 2007 | 03:15 AM
JUICED96Z
Guest
Posts: n/a
Or aftermarket hood
Old May 9, 2007 | 02:45 PM
ls1king000's Avatar
Or nothing HAHAHA
I finally got this intake/elbow to fit without cutting hood/cowl/mounts
I'm very happy I work in machine shop
I machined the intake down the most i could, top and bottom of the elbow, it's clears the hood by a ***** hair
Old May 9, 2007 | 06:26 PM
smoknta's Avatar
Looks good.
Old May 9, 2007 | 09:26 PM
6 & 8 Second Club
I've welded my front plate & block saver, never had a problem with either one.
I would be much more concerned with changing the angle of the motor,
as I mentioned. 1/4" at the motor mount could be an issue,
by the time you get to the rear end.
If welding the mounts makes everything fit, I wouldn't stress out over it. Good luck.
Old May 9, 2007 | 09:55 PM
ls1king000's Avatar
Thanks bro
Since the mounts sit on the k-member @ 45 degrees, If i cut the mounts down 1/4" each, shouldn't it lower LESS than 1/4"?
Old May 11, 2007 | 09:39 AM
Black Sunshine/ 00SS's Avatar
You should be able to cut it down & weld, I have the Madman solid mounts, and they are just a little shorter than the Spohn. I have a pic of the 2 somewhere, when I compared the 2. Let me see if I can find it.
