Drag Racing Tech
Opinions on Wolfe 6-point bolt in
Old May 9, 2007 | 07:52 AM
WFOWS6_IL's Avatar
Default Opinions on Wolfe 6-point bolt in
Just curious to see what you guys think. Is the 6-point bolt in worth it, or should I just get a chromoly setup? Just curious to know if the bolt in will let the chassis flex that much more. My suspension guy said it's $125 a point for chromoly. I was thinking about saying heck with it and getting a 12 point installed, but weiry about cutting up a car with 20K miles on it. I'm starting to have a who gives #$#( attitude at this point though. Plus, I'm thinking of adding some kind of forced induction later on.
I'm expecting the car to run high 10's on motor when I get the rest of the car together. I have the rear suspension all done with a custom chromoly torque arm relocated to the floor pan and the fronts getting a custom chromoly k-member w/arms when the motor's back in. And of course, a chromoly STB.
Any thoughts? Opinions? Probably should just get the 12-point instead of buying the bolt in and then upgrading later..lol! Heck, like that's never happened!
Old May 9, 2007 | 10:10 AM
jay_99z's Avatar
Why wouldn't you go with a 6point weld in?
Old May 9, 2007 | 10:31 AM
brandonppr's Avatar
With your plans it would be cheaper to got 10point weld in. It will be cheaper to do it all at once.
I got my moly 10 point for $700 shipped w/swingouts
tig welded in $750
added bars thru firewall to front frame $150
They did it all at once on a stripped down car.
total cost was $1600 for cage with the addon.
20k miles on your car. that would be a little harder for me mine has 90k. but I would probley do it anyway.
Then you will be ready when you go FI.
I wouldn't do it unless your serious about racing though.
Old May 9, 2007 | 10:39 AM
WFOWS6_IL's Avatar
If I go with a weld in, there's no turning back and might as well add more points and make the chassis as stout as possible.
Just my opinion there.
Old May 9, 2007 | 12:50 PM
brandonppr's Avatar
If its your DD do the bolt in but if your going all out with FI or its your racecar I would do the weld in 10pt
Old May 9, 2007 | 02:17 PM
WFOWS6_IL's Avatar
It's not my DD, but I'm 6'5" and 230lbs. and not for sure how well I'll fit in with a 10-12. Guess that's a consideration too. All ready a tight fit with the seat down and back with the knees close to the wheel and doorcard.
Any tall individuals "totally" uncomfortable fitting in the car with a 10-12 point? I realize it's going to be a tight fit, but I all ready have to roll out of the car to get out...lol! So if it takes me 10 minutes to get in/out then I might reconsider my options.
Money is not a consideration here either, just FYI.
