Drag Racing Tech
ATTN caliper grinders
Old 05-12-2007, 01:10 PM
Ping King's Avatar
LS1Tech 20 Year Member
Default ATTN caliper grinders
BE careful! i almost had a disaster today. My rear drivers side brake caliper snapped in half! I had ground my calipers down to fit 15x10 prostars.
Old 05-12-2007, 01:20 PM
99ssleeper's Avatar
so what happened when it broke? hows that sound? any pics?
i ground mine, but only the mininum for 8" pro stars, and im also running a spacer.
Old 05-12-2007, 01:41 PM
Gary Z's Avatar
Thanks for the warning. I hate to think of the pain and trouble that might result from an accident caused by modified brakes.
Old 05-12-2007, 01:43 PM
Ping King's Avatar
didnt make any sound...just stepped on the brake for the linelock and its sank to the floor. Got out and saw the top of the caliper was missing.
I pulled the brake pad out through the wheel lol
Old 05-12-2007, 06:15 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,231 Likes on 786 Posts
LS1Tech 10 Year
That sucks. I did mine seven years ago and they are still good.
Old 05-12-2007, 11:34 PM
1BADAIR's Avatar
that sucks
backspacing and wheel width doesn't affect how much needs to be ground off cause its the face of the wheel that hits
Old 05-13-2007, 01:10 AM
Ping King's Avatar
wheel type, and if you choose the run a spacer or not is what will determine how much to grind.
Im looking for another set of calipers to grind if anyone knows someone willing to sell a set.
does anyone know if the Lt1 brake setups are smaller in diameter?
Old 05-13-2007, 01:59 AM
rons 00z's Avatar
lt1 brakes will work.
Old 05-13-2007, 08:52 AM
James Montigny's Avatar
Sorry to hear about that man, do you have pics of the grind work (before or after the failure)?
I haven't had any trouble with mine so far.
(I have grinded LS1 brakes on my 93)
Old 05-13-2007, 09:39 AM
Ping King's Avatar
when you say Lt1 brakes will work, does that mean theyll bolt onto the backing plates and all? anyone with an LT1 have any grinding experience?
Ill be posting up pictures soon.
The scary part was that i was getting ready to do my run and couldnt do a burnout with my line lock. i pumped the brakes and realized there was no pressure. Imagine if it failed trying to stop at 130 mph?
Old 05-13-2007, 10:46 AM
LS1Tech Co-Founder
LS1Tech 10 Year
Or get some Aerospace rear brakes.
Old 05-13-2007, 11:57 AM
Retired Street Racer
Matt D's Avatar
I had a brake caliper snap in half on my old '00 at 130mph+. I couldn't slow the car down in time, crashed, and totalled it. I run Convo Pros on my '99 so I don't have to grind.
Old 05-13-2007, 02:30 PM
Ping King's Avatar
thats what im sweating about. If they didnt break duing my burnout, they would have broken at the end of teh track. At least englishtown has a snad trap at the end.
Old 05-13-2007, 03:23 PM
Matt D's Avatar
Yeah there was no sand trap on the street
Old 05-13-2007, 05:32 PM
Mr.MartyStone's Avatar
Will the aerospace setup work with stock rears? I didn't think it would.
Marty
Old 05-13-2007, 05:35 PM
Ping King's Avatar
when you look on their site they say 10/12 bolt GM with parking brakes. Id love to be able to make them work AND reain ABS
Old 05-13-2007, 05:39 PM
DopeFedZ's Avatar
I finally broke down and purchased the aerospace kit.
Old 05-13-2007, 05:46 PM
Ping King's Avatar
how does it work? which kit did you buy?
Old 05-14-2007, 12:10 AM
Taubr Unit's Avatar
i ground mine down some then im running a real thin spacer on the rear so it saved me some material on my calipers
Old 05-14-2007, 12:30 AM
Josh@KY-Turbo's Avatar
What's you wheel tires size and setup? I love the Convo Pro's. I just want them to be tucked in.
