Drag Racing Tech
Moser 9" & Strange brakes problem
Old May 13, 2007 | 07:03 PM
Firehawk441's Avatar
Default Moser 9" & Strange brakes problem
When I bolted up the caliper mounting bracket, the axle can slide in and out. Is there supposed to be a shim that goes between the bearing and the housing? Was Strange supposed to supply it or do I have to get it from someone else? With the axle bearing flush with the housing, the rotor just about scrapes the the bracket and the caliper doesn't line up. Anyone have the answer? Thanks for any help.
Old May 14, 2007 | 10:25 AM
Steve Burger's Avatar
LS1TECH Sponsor
I used a .125 shim between the bearing and the housing. Call Burkhart >>>>. They should be able to set you up.
Old May 15, 2007 | 06:05 PM
Thanks for your help. I already ordered them. They have them in stock.
