Drag Racing Tech
325 DR Band wagon
Old May 22, 2007 | 12:27 AM
roadtrip120's Avatar
Default 325 DR Band wagon
Just got my 325 ET Dr's in and mounted on some new 15x10 pro star's with a 5.5 backspacing. These will go perfect with my6" narrowed, Moser 9" that is showing up on Wednesday.
Here are some pics of the bad boys
Front Zr1 17x9 275 kumho's weigh in at 49lbs
Rear Zr1 17x11 bfg dr's weigh 55lbs
15x10 325et prostar's weigh 52lbs
Old May 22, 2007 | 03:01 AM
revtime's Avatar
Man those make an LT1 car look so bad ***.
I have a Strange 12 bolt shortened 2.5 inches on each side with Weld Pro Star XPs 15x10 with 5.5 BS.
Old May 22, 2007 | 11:16 AM
mthegodfather's Avatar
Very nice.............
Old May 22, 2007 | 02:23 PM
97blkz's Avatar
I have my 12 bolt tucked 3" and the same rims as this guy. Looks great!
Old May 22, 2007 | 04:30 PM
Rogue86's Avatar
Why do they look like they stick out so much more than everyone elses? Most of the 3" per side narrowed rear ends I've seen with 5 or 5.5" of backspacing don't look like they stick out that far at all.
Do you have any better pictures with the car on the ground?
Old May 22, 2007 | 04:58 PM
LOL, like i said my narrowed Moser will not be here till tomorrow. the pics are on the stock 10 bolt, thats why they stick out in the pic
Old May 22, 2007 | 06:06 PM
gator's 99TA's Avatar
they look great and run even better!
Old May 22, 2007 | 08:22 PM
Rogue86's Avatar
Whooops haha I'm an idiot! Be sure to post some pictures of them on the moser rear!!
Old May 23, 2007 | 05:51 AM
skinnies's Avatar
I love my 325's so far, got them hot and on the streets on the 100 shot my car will pull the wheels.
Old May 23, 2007 | 12:51 PM
Whats your setup?
Motor
Hp
suspension?
Old May 23, 2007 | 12:59 PM
bowtierodder's Avatar
Old May 23, 2007 | 06:06 PM
skinnies's Avatar
Heads/cam lt1, th400, 10 bolt with 3.73's, lca's, torque arm, no front sway bar is the only suspension on the car as of now.
Old May 24, 2007 | 12:26 AM
stainless40cal's Avatar
Pics? or vids would be even better..... No doubt here, just sounds like to much fun not to see
Old May 24, 2007 | 12:39 AM
skinnies's Avatar
No pics or vids yet, waiting to put in a good rear end and do some "testing" in the middle of the day so I can get some good pics and vids. I try to limit my launches on the bottle as much as possible right now. Actually I'm pretty sure I just killed this 10 bolt today. It makes some BAD noises, lol.
Here's what the car looks like...
My old camaro on the motor would pull the HEAVY 275's on 17's on the streets, lots of people here in KC got to see those launches. That was on a 275/40/17 mt dr in the rear, but it had full suspension also.
Old May 24, 2007 | 02:59 AM
revtime's Avatar
He can get daylight under those skinnies.
It won't pull em a foot off the ground fellas but they do come off the ground.
I am gonna remove my front shocks so I can bounce wheels up......
Killed the 10 bolt huh? I am starting a 10 bolt graveyard at my place. we can stack em up like cordwood.
Get ya a decent rear in there so we can get vid of both of us launching off the transbrake.
Old May 24, 2007 | 04:46 AM
skinnies's Avatar
Yeah so far I haven't got a lot of air under them, once I get the rear it should go over a foot up.
The camaro went a good 8-10" before on the street.
Old May 24, 2007 | 10:25 AM
skinnys, car looks good with those big meats on it.
Old May 24, 2007 | 11:30 AM
T/ALT1's Avatar
Looking good, I remember when I was one of the only 4th gen running around on those 325's. After having run them, I would have went with a 12" rim to make the tire spread out some more but you would have to do a minitub. Awesome tires though.
Old May 24, 2007 | 12:08 PM
WheelsUp84z's Avatar
Roadtrip what color is that on you're car, thats the best looking blue i've ever seen, and the black ss scoop looks sick as hell too. Those 325's are monsters! you got you're 9" narrowed 6 inches and you are still running 5.5 BS? with 28x12.5x15 QTP's they barely cleared my inside wells and LCA's with 5.5" BS and mine is only 2" narrower than yours stock
Old May 24, 2007 | 06:25 PM
Marine Blue is the color, thanks the paint job turned out better than expected
I am using a 1/2" spacer on the rear too, if you check out "Gator" or "Nasty" they both have the 325 narrowed 3" and the 1/2" spacer, on a 5.5 back spacing.
