Drag Racing Tech
getting rid of power windows
Old May 22, 2007 | 09:28 AM
Optimus_Prime's Avatar
Default getting rid of power windows
I'm wanting to ditch my power windows, is there some kit that I can buy so I can install some roll up windows?
Old May 22, 2007 | 09:49 AM
Slow Z28's Avatar
there has been some posts that the weight of the mechanisms for the crank windows actually weighs more than the electric window setup.
are you doing it for weight or the PITA that the electric window motors are? haha
Old May 22, 2007 | 07:09 PM
Taubr Unit's Avatar
yea, crank windows are heaver then electric ones
Old May 22, 2007 | 08:41 PM
ou812/z28's Avatar
i removed the power windows in my car and weighed them then took the roll up windows and weighed them. the roll up windows or 10lbs lighter than power. oh and that is for each door. so u knock 20lbs off by going to roll up. i bought a 6 cylinder car that was totaled and did the swap.
Old May 22, 2007 | 09:23 PM
Firehawk441's Avatar
No kit. You have to find the regulators in a salvage yard. GM discontinued them. I've done this swap already. VERY SIMPLE to install. I don't recall what the weight differance was,but the power windows including regulators, relays, switches, and wire harness weigh more.
Old Oct 29, 2007 | 12:17 PM
BadAssFast's Avatar
Not as much a matter of weight for me. I don't want to send power to the doors in a weekend race stripped vehicle. I do want to retain the ability to lower the window if necessary. Does it work to simply know a hole in the panel for the crank or will I have a depth crank area issue?
