Drag Racing Tech
MS Excel DA Calculator
Old May 23, 2007 | 11:12 AM
radkon's Avatar
Default MS Excel DA Calculator
Someone wanna check this over for me? I've been working on it for a while and think its pretty close but since my tracks don't provide a lot of info I've had to make it up as I go along. If someone could review it and let me know if its correct or all BS I'd appreciate it.
Last edited by radkon; May 24, 2007 at 07:17 AM. Reason: Made a cosmetic update to the sheet and uploaded new version
Old May 23, 2007 | 02:42 PM
LC's Avatar
LC
Congrats on getting the formula to calculate DA, thats such a bitch!
I see that the formula you used does not add the actual over sea elevation...
just that..
Old May 24, 2007 | 06:30 AM
radkon's Avatar
just that..
Thanks I think I fixed it now
File Type: zip
Last edited by radkon; May 24, 2007 at 08:39 AM. Reason: Revised the calc for base altitude
Old May 24, 2007 | 07:48 AM
RUQWIKR's Avatar
As an alternative...
For true DA, you need the station pressure, which can be plugged in here:
http://www.srh.noaa.gov/elp/wxcalc/stationpressure.html
Then, take that and plug it in here with the air temp. and dewpoint:
http://www.srh.noaa.gov/epz/wxcalc/d...altitude.shtml
The altimeter setting is what is reported as the barometer readings on most weather sites unless it specifically shows it as station pressure. Hope this helps. Take care. Dave
