Drag Racing Tech
View Poll Results: How many run a thermostat in your LS1 cars?
My car is mostly street and I run a thermostat.
72
54.14%
My car is mostly race and I run a thermostat.
30
22.56%
My car is mostly street and I don't run a thermostat.
14
10.53%
My car is mostly race and I don't run a thermostat.
17
12.78%
Voters: 133. You may not vote on this poll
How many run a thermostat?
Old Jun 1, 2007 | 09:24 AM
BADSZ28's Avatar
Originally Posted by brandonppr
So what do you think about the meziere electric race pump?
I don't think it has a tstat. not sure though.
I would imagine it would be great if you run it like Magnus does. Would require some wireing. Or just get a seperate fan controller and hook it up to the pump.
Old Feb 27, 2008 | 06:41 PM
JL ws-6's Avatar
Race your car!
I have ran the stock t stat/water pump up to this point, but am going to a race mez. pump with no thermostat at all. I don't see it being an issue.
Old Feb 27, 2008 | 11:28 PM
RAGENZ28's Avatar
No t-stat, I didn't run one in my old race car and in my Camaro I won't run one, I'll use restrictor plates to keep the water temp where I like it.
Old Mar 1, 2008 | 02:59 PM
jakesz28's Avatar
This car has always been on the raod more then the track but that is changing this year. So I will cut the stock t-stat and use it as a restrictor plate. In past cars I would pull the t-stat and run restrictor plates. I agree about the water can move to quickly and not pull as much heat out of the motor.
Old Mar 1, 2008 | 03:45 PM
JL ws-6's Avatar
Race your car!
That's why the MEZ race pump is only a 35 gpm pump, so the coolant moves slow enough to have a change to absorb the heat.
Old Mar 2, 2008 | 08:02 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I don't run one it the TA
Old Mar 2, 2008 | 04:57 PM
brandonppr's Avatar
UPDATE:
I ended up getting the 55gpm mez pump
I have raced it several times with no stat and so far it is doing great.
Old Mar 2, 2008 | 06:19 PM
BTLFEDSS's Avatar
I am planning on goingwith a HD Race pump 42gpm and BMR Alt Bracket.My car is mostly street driven but i think i'll be alright with a water restrictor in there
BTLFEDSS
Old Mar 20, 2008 | 07:24 AM
2MCHPWR's Avatar
i will run with no t-stat to this season. i did it on a road course last year for one event with no issues.
does the t-stat route the water a specific path and with no t-stat, does the water go the wrong way? a tech at evans told me that but I just don't think so.
Old Mar 20, 2008 | 07:40 AM
JL ws-6's Avatar
Race your car!
no, water will just flow with no restriction. Which is why mez. made the race pump @ 35 gpm, so the coolant will move a little slower, making the need for a t-stat not needed.
I'm gonna be installing my pump tomorrow, and there's no hint of a tstat going in anywhere.
Old Mar 22, 2008 | 03:12 PM
RAGENZ28's Avatar
You tune the flow with restricter plates, if you have a high flowing pump and it's running on the hot side you put in a smaller restricter plate, you can swap the plates in and out until you find the one that works best for you, most kits come with 3 plates.
Old Jun 6, 2008 | 06:39 AM
  #32
Matt D's Avatar
Retired Street Racer
I have the same setup as Keith (Magnus). I drove it last night to a car show, 85* out, and it never went over 170*.
Old Jun 8, 2008 | 09:56 AM
  #33
1BaadGoat's Avatar
Originally Posted by Magnus
I don't run a thermo in my race car..
My PCM controls my elec water pump and race fan. It does a good job of keeping the temp I want.
ALL Vehicles need to run a T Stat or a Restrictor, not running one will not slow the Water / Coolant down for it to cool properly.
Old Jun 8, 2008 | 03:11 PM
  #34
cablebandit's Avatar
i just tried this with my 408..lt1 rad and stock ls1 wp. no stat made it run hottest....stock stat was a good bit better and 160 stat was best.
Old Jun 9, 2008 | 09:29 PM
  #35
Matt D's Avatar
My car runs the same temp in 35* weather and 90* weather. You don't need a thermostat.
Old Jun 10, 2008 | 12:09 PM
  #36
Phil99vette's Avatar
7 Second Club
Setup:
438" Iron LSx with ET LS7 heads
Double pass radiator
5x gpm Meziere pump wired to come on with engine running all the time
1600cfm fan turns on 185 off 175
engine stays a nice 180 degrees.
Old Jul 10, 2008 | 04:50 AM
  #37
JL ws-6's Avatar
Race your car!
I have no t-stat, waterpump is on a switch so I can turn it on and leave it on if needed.
I only have the factory temp guage so the accuracy of that is questionable, but I know that before with the stock pump/tstat the car would get up to 200 and never go over, and now it says a touch under never really goes over. And that is on a day when it's a goos 85 to 90 outside and making 2 passes within a 1/2 hour. My fans come on at 170 and go off at 160 (so once the car is running, they just pretty much stay running) and I have no problems.
All I have in the radiator is water too, no water wetter, no coolant, just regular old tap water, no problems.
Next year I will probably put a big single fan on it and wire it with the waterpump just so I can turn the fan on and off with the waterpump.
Old Jul 11, 2008 | 10:03 AM
  #38
Cheatin' Chad's Avatar
lol oh man.. the coolant will have PLENTY of time to soak up the heat, trust me.
I agree 100%. The train of thought that says you need to slow the coolant down to transfer heat is an old wives tale.
It's better to remove restrictions and increase flow.
Old Jul 11, 2008 | 10:10 AM
  #39
JL ws-6's Avatar
Race your car!
Finally someone that gets it
