How many run a thermostat?
Derek
My PCM controls my elec water pump and race fan. It does a good job of keeping the temp I want.
I have been running a regular waterpump with the thromo removed since I started racing it.
I bracket race it and double enter 3 classes a night. The car runs down the track constently. with the thermo in it gets too hot. I took the thermo out now it sets about 190 in the winter and 200 in avg whether and 210 in the heat of the summer. it now keeps the temps about the same all day instead of going up and down. its easier to keep the temp the same and be more constisant doing so. I only sometime have a problem when it gets in later rounds and they are waiting on me at the starting line and the car doesn't even have a second to rest it will sometime get about 10 degrees warmer than it has been earlier in the day but it never gets hot. I have driven it on the road several times and had no problems.
I am getting an electric waterpump when I get it back togather, I am hoping that will help me a little in those tight rounds I can cut the car off and coast it to the starting line while the pump is working.
If it was still in it would overheat when I hotlap it.
been running without for 3 years now.
Derek
I have a 160 stat.
I tryed it with a manual fan switch and ran the fan the whole time and read the temp from the computer. It still got up to the same temp but when the thermo stat opened it dropped the temp faster than normal. My car was track only and I bracket race so I want it the same temp all the time and with the stat in I had no control over the temp it just went up and down all the time by about 30-40 degrees. After taking it out it run much cooler and stopped going up and down.
PCM Fan 1 output controls water pump.
PCM Fan 2 output controls my fan.
I kick the water pump on at 160, it will cool down to like 145 then, and heat back up past 160 until the fan comes on.
I think what people are saying is if you do not regulate coolant flow, the coolant will not have time to soak up the heat from the block and heads before moving to the radiator to disipate this heat, therefore you will be getting a false engine temp reading by not having a t-stat since it is reading the coolant temp without removing much heat from the engine, leaving the coolant cooler.
I don't think it has a tstat. not sure though.
