Drag Racing Tech
View Poll Results: Which trans
Powerglide w/tbrake
14
58.33%
3speed th350 or th400 w/tbrake
9
37.50%
4l60e w/ tbrake
1
4.17%
Voters: 24. You may not vote on this poll
Which trans for bracket/index racing?
Old Jun 1, 2007 | 08:30 AM
Ken95Z28's Avatar
It's an 8" ATI 4500, running 1.76 first gear.
Old Jun 1, 2007 | 02:39 PM
Hrod382's Avatar
I know of plenty of cars that went from leaving very lackluster to near putting it on the bumper by swapping to a 1.96 first. My dad owned a motor in a car running ~6.60's and it barely picked up the wheels then swapped to a 1.96 and it was a wheelstander.
Old Jun 2, 2007 | 07:50 PM
Gary Z's Avatar
Originally Posted by Hrod382
...with a 3 speed you have to shift it while the car is on the stop which gets tricky.
What does "on the stop" mean and why is shifting there tricky. Thanks - Clueless M6 Guy.
Old Jun 2, 2007 | 08:46 PM
brandonppr's Avatar
Throttle Stop
An aid which helps drivers adjust the performance of the vehicle to match the index of the class. For example Super Street. The index is 10.90 So you want to run that number. Most of the cars can run mid to low 10's but use a throttle stop to slow it down enough to run the index of the class. Most racers activate it in the first 60ft of the run. Its kinda like letting off then flooring it again but it does it for you.
What Hrod382 is saying is that during the time that the Tstop is activated you would be shifting with a 3speed. It would make shifting harder. also most have manual valvebody trans so a selinoid or airshifter shifts at a certain RPM and the car will not downshift by its self. you just pull it down to first and when you leave the starting line it shifts and when you get to the finish line it is in 2nd or 3rd gear till you pull it back down.
