Which trans for bracket/index racing?
I will be index/bracket racing on a tbrake.
running 1/4 mile and 1/8 mile.
mid 10's.
3000-3150lb raceweight
450ish rwhp NA
which one will be most consistant?
Just my $.02, I'm running a TH400 now and love it, but mid 10s and quicker I'll likely same the $$$ for a 'glide.
Derek
Derek
mid 10's.
450ish rwhp NA
I plan to run Super Street in the future. I figured PGs were allowed but I don't know for sure in Super Street.
I think the best way to answer your question is to provide the following. In bracket racing why do 99% of the people run this tranny? Auto / Manual
I don't understand what you are saying on the second part of the post???
do you think the PG will be OK with only 450HP?
I am going with a 28" tire.
I have another question that is a little off topic.
I am NA now and will be aroud 450rwhp, Would a supercharger hurt consistincy? Would staying NA be best? I would love to have a little more power but I am pretty close to the most I can probley get out of this 347ci. maybe more compression but thats probley not going to give me enough. I would rather it be a closer to 10.00's so I can be on the Tstop a little longer. Will a Tstop even work with a supercharger?
I am not familiar with Tstops. Do they have to have to be on a carb? will they work on the stock fuel injection?
Thanks for the help!
If I was going to go Super Pro,HR/SST I'd run a PG for sure.
I would run the PG if I had to do it all over again. With that being said, I run a turbo 350(no t-brake) with a 5000 stall convert behind a 347. We do ok, braket racin and run between 10.20 to 10.35 depending on the time of day/year & weather.
I was always told that if I put a PG in my car it would slow her down, but she would be more consistant.
Coach
PS. If your going to run Super Pro,HR/SST You have to CUT A LIGHT & DIAL HER TIGHT!
I wouldn't be too concerned with what it runs, honestly they're a little easier to set up when they're closer to the 10.90. When we were running high 9's-low 10's it was easy to go anywhere and get it close, once it was mid 9's there's so much of a variation in how long it has to stay on the stop we would struggle when we unloaded at a new track.
I kinda miss having overdrive but oh well..
Just wanted to project my 2 cents. With 500 HP and 3000+ lbs, a 350 with brake, will be plenty strong. Gives you a better launch, than glide, and less loss than 400. If you are going to step up, than glide all the way. As some have said. My opinion, low power cars like the 3rd gear. I didn't switch to glide until ~9.50 N/A and 8.80 spraying. Good luck.
The 60's are not as good with the 4L60E that I had but the 60's are more consistent. When you run a marginal prep track the PG is a way better choice then the 3 and 4 speed autos.
On the dyno my car had 378 RWHP to the wheels, a loose converter 4500. Look at time in my signature that was a decent cool day, typically during this time of the year it's in the 11.20's to low 11.30's in the 120 to 121 mph range.
what first gear in the pg?
