Drag Racing Tech
"Cross Bars" vs. single Door Bar?
Old Jun 1, 2007 | 09:48 PM
THE_SUPRA's Avatar
Default "Cross Bars" vs. single Door Bar?
Hey guys, first off I want to say, I’m not sure the exact terminology, so I will call them "Cross Bars", I am talking about running two bar that intersect in the door making an "X"...
Anyways, I was working on the chassis of my race car today. I cut, notched, and tacked in the regular door bars. While I was at it I fabbed up the upper section to utilize a "Cross Bar" setup.
My question is, what is the advantage of using a cross bar setup? Just chassis strength, or is it more safe as well?
Also is their a time/bracket that requires this type of design?
Old Jun 1, 2007 | 11:28 PM
pdanrichey's Avatar
Oh ya!!!
Old Jun 2, 2007 | 12:24 AM
9sec93's Avatar
you can use a smaller diameter door bar when using the X brace.
Old Jun 2, 2007 | 08:54 AM
THE_SUPRA's Avatar
so its a weight savings thing?
Old Jun 2, 2007 | 02:14 PM
98CamZ28's Avatar
No, you're still adding extra bars so it will be heavier. It's a safety issue and i'm sure it can't hurt the chassis stiffness. I believe it starts when going faster than 8.50/25.5 cert.
Old Jun 3, 2007 | 12:43 AM
68maro's Avatar
7 Second Club / STF Veteran
8.50 and 25.5 are 2 totally different certs.
Old Jun 3, 2007 | 10:25 AM
mrdragster1970's Avatar
6 & 8 Second Club
Strength, stiffness, and better protection from a side impact. After seeing the Bruce Allen crash, I'm adding a bunch of bars to my slow car. Fast car is already 6.0 certed. If you're not worried about weight, too much. put the X in, and maybe a F/C cage or a partial F/C cage to protect your head & neck. Good luck.
Old Jun 3, 2007 | 11:45 AM
98CamZ28's Avatar
Sorry, not an expert but isn't 8.49 - 7.50 right at what a 25.5 cert is good for?
