Drag Racing Tech
If you run between a 11.0-11.5 what is your 60' time?
Old 07-06-2007, 08:34 PM
jakesz28's Avatar
Originally Posted by Torkman15
Jeez I was making 1.47s before I put a real quiet muffler on. I'm doing 1.55 60s now and only running 10.70s @ 128 down from 10.40s @ 133 with a straight thru muffler. All motor (346) true single all the way out the back 3in exhaust w/Hooker aerochamber and slipping clutch.
I'm thinking deep 10s with that 1.47 60ft time. Your car must be real light with a loose converter.
I have only removed about 150 pounds( I weighed everything I removed). I have a vig 3600 that works nice on the street. When I pulled that 1.48 sixty foot I was leaving the line on a 200 shot so she flashes pretty high. I'm still mad that I had to get out of it. When I staged for another pass the spiders got chewed up.
Old 07-06-2007, 10:19 PM
Grr
Grr's Avatar
i usually run a 2.1-2.25 60', 11.5-11.7 at 125-128 mph.
stock 14" 1900 stall 4l80 converter and full wieght GN, 3700#s. Really need that 4000 stall, should do 10.5's then.
Gary
Old 07-06-2007, 10:54 PM
SuperC1's Avatar
11.4 with 1.6 sixty full weight SS
Old 07-08-2007, 08:48 PM
bad2000z's Avatar
1.54-1.56 with 255/50/16 M/T drag radials.
Old 07-08-2007, 11:40 PM
Demonicbird00's Avatar
1.49-1.53 range here
-brandon
Old 07-09-2007, 12:27 AM
TwoFast4Lv's Avatar
I am 1.6s-1.7s N/A with a 116-118 trap.
then again I am only high 1.4s a 10.0
Old 07-09-2007, 10:17 AM
MARKSZ71's Avatar
Quick Reply: If you run between a 11.0-11.5 what is your 60' time?
