Drag Racing Tech
Need help with tire pressure and shocks
Old Jun 10, 2007 | 10:59 PM
dnkynrbk's Avatar
Default Need help with tire pressure and shocks
Here is my deal I have MT drag radials 275/15 ran them at 15 psi cold air temp. I have qa 1s I had the fronts set at 1 and the backs 7 and 8 on the passanger. With iron block. My problem is when I spray a 150 shot and I have the window switch set on 3500. Im spinning when the nitrous hits about 10 feet off the line and the tires break loose and spin for about 10 feet then hooks and launches. Im stalling the car to 1800 rpmss using a 3200 stall the car lauches off the line well but when the nitrous engauges the tires break loose and my 60ft are around 1.75. do I need to loosen the rears shocks. And in the burn out pit how hot do you get these? thanks.
Old Jun 11, 2007 | 12:04 AM
DMH Fabrication's Avatar
The MT drag radials don't need to be heated up much. Just spin them to you start to see smoke and that should be enough. Thats my experience at least with the 325 MT DRs.
Old Jun 11, 2007 | 07:07 AM
MADMAN's Avatar
LS1Tech Sponsor
The rear shocks should be the same on both sides. Try backing your timer up. You should have the NOS on as quick as possible. A short burnout also helps.
__________________
www.madmanandcoracing.com
225-343-9029
