Drag Racing Tech
MT drag radial not hooking need help
Old Jun 13, 2007 | 08:47 PM
Cobra Commander's Avatar
I have the same problem spraying out of the hole.
Big burnout at 20 psi: spins
light burnout at 20 psi: spins
then again I'm on stock wheels so I'm limited to a 255/50/16
Old Jun 13, 2007 | 08:58 PM
gator's 99TA's Avatar
i have liked the higher PSI in my 325 m/t radials. the lower psi worked well on the transbrake if the track was very good. otherwise it wheelhoped like a mother. 20 psi on teh footbrake spraying out of the hole worked but i dont make a ton of power either. my car has gone 1.37 60' on stock heads and a wet 125 shot on the footbrake.
By Brett Foote | 2026-06-04 05:00:17
