Drag Racing Tech
Summit Drag Wheels
Old Jun 24, 2007 | 08:02 PM
AINT SKEERED's Avatar
my dad ordered his from summit 3 months ago and were on back order, he never recieved his so he canceled and went with welds,
Old Jun 24, 2007 | 09:36 PM
Black_Bird's Avatar
Has anyone checked the weight on these? I've heard before that the Summit wheels are pretty heavy, I dont know though so I'm asking.
Old Jun 24, 2007 | 10:15 PM
Photochop's Avatar
I wonder what these weigh compared to the jegs brand 15x4 prostar lookalikes? I've got those on my car..they look identical...wonder if it's the same company doing both of them?
Old Jun 24, 2007 | 10:57 PM
6techniques's Avatar
Good f'n find man! That is music to my ears now that there is potentially no grinding involved.
Old Jun 25, 2007 | 12:29 AM
slmdLS1's Avatar
interesting....
Old Jun 25, 2007 | 02:02 AM
gnbooster87's Avatar
Originally Posted by obrien24
http://store.summitracing.com/partde...5&autoview=sku
the 15 x 4 has a 1.75 offset, the 15 x 8 has the 5.5 available.
these 15x8 do they fit with the stock calipers without rubbing or do you have to grind them down? also do they pop out the qpanel or flush right in?
Old Jun 25, 2007 | 11:03 AM
cwaldt's Avatar
I went with the Jegs wheels. 15x4 in front and 15x10 in back. The rears are 4.5 bs with a 3" narrowed on both sides MOSER rearend. Look under my post and you can pull up pic's I love the setup and everything fit perfectly.
Old Jun 25, 2007 | 11:49 AM
transamfreak01's Avatar
do they make these in 17's in the back
Old Jun 25, 2007 | 01:46 PM
CRZYPWR's Avatar
Funny how both of the companies won't make the 15x10 with 7.5 back spacing. It's either 15x10 with 4.5 or 15x8 with 5.5.
Stupid if You ask me... why not make such OBVIOUS size wheel.
Old Jul 9, 2007 | 10:53 PM
sixvi6-camaro's Avatar
figured I'd bring the post back since I might be buying a set the summit star fronts from my neighbor. He's got a C4 project car he was going to run these on but is going with a different setup. I borrowed one to check out and test fit and took some pics before I decide if I want them or not. too bad his rears are totally wrong offset for my car.
first off weight with the valve stem and center cap..
and another pic... Rear shot (56K.. Large Pic to see the stamping on back)
The look good and I might just pick these up after I see what I'll need to do to get them to clear my calipers tomorrow. Hopefully when the rears are in stock they will clear our brakes with little or no grinding but I'm not going to keep my fingers crossed.
Old Jul 10, 2007 | 10:12 AM
Matt D's Avatar
Retired Street Racer
Holy cow those are heavy! My 15x4 Convo Pros weighed 8lbs and the rear 15x7.5s were 10lbs.
Old Jul 10, 2007 | 04:36 PM
  #32
vtec's Avatar
Resident Racing Jerk
i wonder if these are the old weld xp's? funny these popped up on the market right after the weld xp left the scene. i know those were one piece wheels with more clearance than standard welds, but heavier.
Old Jul 10, 2007 | 04:41 PM
  #33
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Funny, they could be.
Old Jul 10, 2007 | 07:11 PM
  #34
now that you mention it...they might be, lol.
Old Jul 10, 2007 | 09:39 PM
  #35
you know what they just might be but I thought the XP's will used the shank stlye lugs? either way.. I bought them from the neighbor this evening. they cleared my stock calipers with 1/8" of washers as a spacer on the test fit. I'm still going to run a nice 5/16" spacer just to be sure they clear though.
Old Sep 11, 2007 | 04:36 PM
  #36
s10blaza's Avatar
Bringing this up to let everyone know that the rears go on stock brakes without grinding either. I decided to grind a little off the corners but I didn't spend more than 4 minutes with the grinder. My pads and rotors are barely about 2 months old too. Check it out
This is why I think they don't hit, there are no welds to interfere since this is a one piece wheel
Fronts went on flawlessly as well
Honestly I couldn't be happier. Not bad for less than $800 in wheels+tires
Old Sep 11, 2007 | 04:44 PM
  #37
Project Dc2's Avatar
subscribed.
how much were the wheels and what offset did you go with ?
Old Sep 11, 2007 | 05:08 PM
  #38
s10blaza's Avatar
$430 from summit, and about 350 in tires and lugnuts. fronts are 15x4 and rears are 15x8 5.5BS
Old Sep 11, 2007 | 05:22 PM
  #39
01BlackCamaroSS's Avatar
they look really good dude im thinking abuot picking up a set off these this winter
Old Sep 12, 2007 | 08:54 AM
  #40
RZRSEDGE's Avatar
My buddy put a set on his 02 WS6 and had to lightly grind the front. The rears had to be ground to a very dangerous level. Way more than I had to for the Prostars on my car. His had a lip on the inside of the wheel where it met the rim. I didn't see one in the pic. They may have corrected this now; if so he's gonna be pissed
