Drag Racing Tech
Summit Drag Wheels
Old Jun 22, 2007 | 11:02 PM
obrien24's Avatar
Default Summit Drag Wheels
I recently ordered a pair of the summit star drag wheels for the front of the camaro. All I have to say is I couldn't be happier. The stock lug nuts work, and there is no need for spacers to clear the calipers. The wheels look just like the Weld Prostars, but are a 1 piece wheel instead of a 2 piece. They are about 4lbs heavier.
Old Jun 22, 2007 | 11:13 PM
ls1pwrdss's Avatar
man they do look good so no grinding and no spacers rite
which lug nuts did u use
Old Jun 22, 2007 | 11:50 PM
obrien24's Avatar
I just used my stock lug nuts. There is no grinding or spacers for the front wheels. Hopefully I can get a set of rears soon and I can let you know how those fit. My calipers have been ground, but I am sure I can find a car with stock calipers to see if they fit. Best part is the front 15 x 4 wheels are only $89 each.
Old Jun 23, 2007 | 12:21 AM
Havok2's Avatar
the rears are the wrong off set
last i checked they only offered 4.5 and 5 inch backspaicng, we need 5.5
Old Jun 23, 2007 | 12:57 AM
obrien24's Avatar
The sales rep told me they have a 5.5, but he could have been wrong.
edit...
just checked the web site, and the 5.5 will be available it looks like in august.
Old Jun 23, 2007 | 02:03 PM
ski23's Avatar
DOH!!!!! you dirty dog.i got mine in last week and installed them. wouldnt fit, so i threw on the 5/16 spacer and there on. im runnin new ws6store drilled and slotted with new stock pads so that may be the difference. the ws6 store are alot thicker than stock. im gonna attempt to grind down the calipers to see if I can get them on without spacers. what tires did your go with? i was gonna buy some MT from my uncle but they were dry rotted so i got some kuhmos from discount for $32 each
Old Jun 23, 2007 | 02:52 PM
obrien24's Avatar
I just picked up some of the Metric 165r15s from the local speed shop. If I had more time I would have have ordered the kuhmos from tire rack. I quess I will see what happens with the calipers when its time to put on new pads and rotors.
Old Jun 23, 2007 | 04:07 PM
WS6TransAm01's Avatar
CARTEK Racing
5.5 will stick out with a 10" wide rim
I use 7.5" Backspacing with my Weld Pro-Stars 15x10's with a 28x10.5 15 ET Drag. Fits uder the car, does not stick out, looks good!
Old Jun 23, 2007 | 05:00 PM
Havok2's Avatar
i meant 15x8 of course......
Old Jun 23, 2007 | 06:38 PM
transamfreak01's Avatar
can you send me the link to those b/c i cannot find them on the site it keeps coming up with soem error
Old Jun 23, 2007 | 09:55 PM
gator's 99TA's Avatar
good post jeff
Old Jun 23, 2007 | 11:33 PM
CRZYPWR's Avatar
$89.00 ? Can't see it, would You mind getting a link for me please? Thanks!
Old Jun 23, 2007 | 11:55 PM
obrien24's Avatar
http://store.summitracing.com/partde...5&autoview=sku
the 15 x 4 has a 1.75 offset, the 15 x 8 has the 5.5 available.
Old Jun 24, 2007 | 12:45 AM
CRZYPWR's Avatar
And these fit right on w/o problem? No caliper issue.. wow. That's nice.
Too bad they don't have 15x10 with 7.5 BP.
But I guess You can just match it up with pro stars.. since they look basically the same. But than again I think 27x10 tire would fit on 15x8 rim..
Old Jun 24, 2007 | 05:44 AM
vtec's Avatar
Resident Racing Jerk
im trying to figure out how the stock lug nuts work on these wheels......
Old Jun 24, 2007 | 09:22 AM
They dont require the conical lugnuts like the welds do. weld doesnt make these wheels.
Old Jun 24, 2007 | 09:42 AM
vtec's Avatar
welds dont use conical seats...
if one piece, how thick are these? 1/2" or so? i was thinking telstar/warriors are made this way, but they dont use conical seat lugnuts either.
Old Jun 24, 2007 | 11:04 AM
yeah im trying to find ones for the rear also but im having no luck... anyone have a link to that?
Old Jun 24, 2007 | 11:05 AM
abd im looking for something that will fit my stock size tire so i can throw my mt dr on it
Old Jun 24, 2007 | 11:46 AM
CRZYPWR's Avatar
Wow, that's a deal.
15x4 Stars for 89.00 ea + 165/80/15 for 32.00 each.
Thanks a lot for the post man, saved me some money!
